Thread: dhp bin file for 3.05 or 3.29 to 2.93 conversion
Results 1 to 4 of 4
  1. #1 dhp bin file for 3.05 or 3.29 to 2.93 conversion
    Kemmerer, Wyoming
    the transmission has gone out on my father in laws 2003 impala. it has a 4t65e in it and I have a spare transmission out of my 2001 gtp. the impala either has a 3.05 or a 3.29 gear ratio, but the gtp has a 2.93. I am wondering if someone could write a dhp bin file for a stock 2003 impala with the correct gear ratio conversion. I will have my father in law look at his car and find out which final drive ratio it has.
  2. #2 Re: dhp bin file for 3.05 or 3.29 to 2.93 conversion
    Marshal - you have a dhp and all the files you should need. Open your fathers car's file and a file with 2.93's. Then simply copy the trans over from the 2.93 car to the Impala. Poof.. you are all set, although you might want to consider adjusting the shift points. Take a look at the most current file in 2000 Regal under Bostick. That's the one i'm using with 2.93's on an NA motor.
  3. #3 Re: dhp bin file for 3.05 or 3.29 to 2.93 conversion
    Kemmerer, Wyoming
    That sounds pretty simple, thanks for the help
  4. #4 Re: dhp bin file for 3.05 or 3.29 to 2.93 conversion
    Bastard Reptile's Avatar
    Kansas City, MO
    Yup, it's that simple. Drag and drop
  1. need a dhp bin file for 99 gtp
    By onalky87 in forum PCM Tuning
    Last Post: 06-18-2012, 11:32 PM
  2. Need a Bin File
    By SerenityGTO in forum PCM Tuning
    Last Post: 06-08-2011, 01:14 PM
  3. Transmission bin file to another bin file?
    By Pure2sin in forum General Tech Discussion
    Last Post: 11-10-2010, 07:11 PM
  4. BIN File
    By Dragon1972 in forum Off Topic Discussion
    Last Post: 09-10-2010, 04:51 AM
  5. DHP file
    By TheOtherNick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-25-2009, 02:51 PM
