Thread: 16.4 LTFT after Injector install
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    Ok so my fuel trims where within 5% +- with stock injectors. I installed some cobra 39lb injectors and scaled the IFR table according to new injector size. Now at idle and light to moderate throttle fuel trims are pegged at 16.4...when I get into PE drops to 0 like normal my Wideband is also showing me cruising down the road at 14.4 to 14.7 AFR. What am I missing? Did I do something wrong? I sprayed around vacuum lines and didn't change anything. Also noticed at idle the BBV opens and closes every 5 seconds or so...can't say I have ever noticed that before...Please help I am a newb at this tuning business
    08 G8 GT - exhaust Tune
  2. #2 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    what was your new number you poked into HPT?
  3. #3 Re: 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    Don't remember off top of my head but hour after I started this thread I dropped the stock ifr numbers back into my tune let it idle for a few mins and fuel trims dropped to within 3% and idled right at 14.7afr...weird sauce so tomorow going to drive around and do some logs
  4. #4 Re: 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    Stock IFR table is sloped from 29 to 34...when I first installed the injectors setup the table for 36 to 43 as I remember...going to try do some logs tonight or tomorow
  5. #5 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    with headers/xp cam, you typically will max the trims at idle due to exhaust leaks and cam overlap.
  6. #6 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    should be 34-40
  7. #7 Re: 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    Yeah it would max them at idle and cruising around only time it would come off 16.4 was when I went 50% throttle or more...I plug in those numbers see how it goes...thanx DH
  8. #8 Re: 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    34-40 worked great! Couple maf tunes and she is a lot better...thanx darkhorizon!
  9. #9 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    Stay away from maf tuning. Use the ifr table unless there is something very obvious that you are sure needs to be fixed in the maf table
  10. #10 Re: 16.4 LTFT after Injector install
    Arizona
    Why not do a writeup on......why you don't maf tune after changing up components that affect airflow?
  11. #11 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 91parkave View Post
    This car in this thread is cam only. There is no ported tb in sight or implied. You have also said it in other threads.
  12. #12 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    Because there is nothing to write.
    You are not changing the density/mass of the air the maf is reading when you put a cam in.... So why is it you are going to change the table that translates it.
  13. #13 Re: 16.4 LTFT after Injector install
    Arizona
    if you're increasing the airflow or the "efficiency" by pulling more air in then then before. The g/sec for that hz rating will not be the same
  14. #14 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    I used a maf and a spare ecu to run a flow bench for my buddys head porting deal... its a calibrated sensor so I used the table in the pcm to translate into mass air flow as it was improved or worsened at the head port.
  15. #15 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    .... if the motor moves more air then the sensor will read the more air coming in... you are not changing the mass of the air with a different cam under the lifters unless you have some sorta laws of physics bending machine inside the cam.
  16. #16 Re: 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    I readjusted the maf because I dropped pulley sizes and afr wasn't right from setting ifr wrong before
  17. #17 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    Quote Originally Posted by wa04compg View Post
    Yeah, setting it back to stock is the best option.
  18. #18 Re: 16.4 LTFT after Injector install
    Oct 2011
    Puyallup WA
    How do you achieve your AFR if you don't maf tune
  19. #19 Re: 16.4 LTFT after Injector install
    Feb 2009
    flintnasty MI
    It shouldn't need adjustment and if it does you can use pe to adjust things. Youll want to tweak the injectors first to make sure they are close as they can be.
  20. #20 Re: 16.4 LTFT after Injector install
    Arizona
    Or you could adjust the MAF to see the actual amount of airflow its getting. And not rape your pe table.
  1. -22 ltft
    By indygrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2014, 02:16 PM
  2. Ltft @ 16?
    By rperry435 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2012, 09:53 PM
  3. ltft?
    By jim97regalgs in forum PCM Tuning
    Last Post: 10-14-2011, 09:01 PM
  4. LTFT all over
    By duane9586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-03-2009, 10:07 AM
  5. ltft +12 help
    By DOUGLASMELTER in forum PCM Tuning
    Last Post: 10-22-2009, 06:39 AM
