Thread: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
Results 1 to 20 of 31
  1. #1 Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    I am coming close to getting the car re-assembled, and i'm not sure what to enter into this HP tuner magic box before turning the key. Also have never used the tuner yet, it just got here today. Rebuilt TEP trans with 3.29's #65 deka injectors intercooler 1.9 rockers p&p blower with a 3.0 pulley slp headers AEM wideband Stock cam....for now. I understand the gear change is an easy edit to a single box, but what do I need to change for the injectors? I looked over at the HP tuner board but the link to an injector spreadsheet is dead. Im just looking for someplace to start with the larger injectors I dont think I can just fire the thing up with twice as large injectors than it had. I went with the really big ones in hopes of tuning for e85, and I already have the fuel pump rewire and Tahoe filter in place.
  2. #2 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by 01Blackgtp View Post
    I can send you some injector flow data that should get you started with those 65#ers. I'll attach it to this thread later today
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  3. #3 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Feb 2009
    flintnasty MI
    Dont really need injector flow data... they are 60# injectors... running e85 so your new injector constant will be between 42 and 45. Put in something near the middle of that and adjust accordingly.
  4. #4 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    May 2014
    Colorado
    What about for 91 octane what numbers should I plug in to start it the first time?
  5. #5 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    May 2014
    Colorado
    Pulled the file from another car with the 60's in it and looked at the IFR vs KPA table and the numbers across the board were way higher 58 to 61 across the table. You sure it should be 42-45?
  6. #6 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    Was that car running pump gas or E85?
    2002 GTP sedan:
  7. #7 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    May 2014
    Colorado
    Right, now I understand, and I am clearly an idiot. The 58-61 table is for 60#s on pump gas the 30% increase from that would be the 42-45. The numbers work backward from how I was thinking it should.
    Still learning what all these tables and numbers do.
    What about pulse width? does that need to be changed anywhere?
  8. #8 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    I just installed 60's this morning on my GTP and only changed the IFR table. Here it what the table looked like:
    Throttle%: 0 10 20 30 40 50 60 70 80 90 100
    Fuel Flow: 62.0 62.9 64.0 65.5 65.9 66.0 66.2 66.3 66.4 66.6 66.9
    Didn't touch PW or anything else. Seems to be doing just fine. Minus the fact that my fuel trims are all over the place at the moment until I get into PE mode.....
    2002 GTP sedan:
  9. #9 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Arizona
    whats youre FPR 43 or 58psi?
  10. #10 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by 91parkave View Post
    I just have the stock one that came with my 99 GTP.
    2002 GTP sedan:
  11. #11 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Arizona
    It's important you know your rail pressure you should be right at 48-52 ish of rail pressure for a gtp. Which of course would dictate your injector flow rating.
    Try 63.2 63.9 64.8 65.3 65.0 64.5 63.4 62.7 61.8 61.6 61.3
  12. #12 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    Interesting. Is it normal to have the numbers in a decending slope relative to pressure as shown? I just went for a good drive and fuel trims seem a bit more reasonable now (still high though). I was thinking about subtracting 1 or 2 from the entire table...
    2002 GTP sedan:
  13. #13 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Arizona
    Quote Originally Posted by 97AutoXVette View Post
    Exactly youre slope was meant more for a steady state returnless system since your a return style and also under boost your IFR will be a little diffrent.
    Id also load in the injector offsets and see where that takes you, Id highly recomend always starting off the injector data per manufacturer inserted. Then you do what you have to do, but atleast your foundation is right IMO
  14. #14 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    appreciate everything. Some good info, and I was unaware of how the FPR functions in this case between when the engine is in vacuum vs boost. I'll upload the IFRs you mentioned above this afternoon and see how my trims look. I'll post some results to this thread later today or tom.
    thanks again! (Feel like I am totally thread jacking at this point. Sorry op!)
    2002 GTP sedan:
  15. #15 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    May 2014
    Colorado
    No its good info, i'm copying numbers down too!
  16. #16 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    This is a pretty interesting article:
    http://www.hptuners.com/forum/showth...ector-IFR-help
    Talks a lot about when flat vs. skewed IFR tables are used, and why. Some parts are confusing, but overall, a good read!
    p.s.. Last night I scaled my 33# (36) stock injectors up to my new 60s by just multiplying the stock table by 60/36. Fuel trims are much more reasonable now (+/- 5%) and seems to be running well. I'll be logging more data to see how it does as the week goes on, but figured I would share that approach!
    2002 GTP sedan:
  17. #17 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Arizona
    I had quite the headache getting my 50#s figured out.... glad you got somewhere though for now.
  18. #18 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    Did you ever end up changing anything besides IFR by chance? Not sure if I should consider gain/offset as well, etc.
    2002 GTP sedan:
  19. #19 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Feb 2009
    flintnasty MI
    stock injectors are 33#
  20. #20 Re: Rebuilt everything and I need some guidance. (Injectors,gears,e-85)
    Mar 2014
    Cincinnati, OH
    Thats what I figured but when my LTFTs were high, figured I would make my IFR table a bit smaller and see what it'd net me.. I also saw something on ZZP's site suggesting some call the stock injectors "36lb injectors".. Not sure where that is rooted though
    2002 GTP sedan:
  1. Need a little guidance on this.
    By MrPoopyButthole in forum Audio, Security & Visual Electronics
    Last Post: 06-16-2013, 05:46 AM
  2. Who have got their ECBM rebuilt? Where did you get it rebuilt ? How is it now?
    By Kelben B Watson in forum General Tech Discussion
    Last Post: 10-10-2012, 07:09 PM
  3. Guidance on my LED build
    By Elfreda Blau in forum Audio, Security & Visual Electronics
    Last Post: 08-11-2012, 05:11 PM
  4. Guidance
    By Brniidgirl in forum General Grand Prix Discussion
    Last Post: 01-22-2012, 08:43 PM
  5. Need help and guidance
    By elmac in forum General Tech Discussion
    Last Post: 03-01-2009, 12:52 AM
