Thread: E85 afr
Results 1 to 13 of 13
  1. #1 Re: E85 afr
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Shmoke View Post
    Is there a generally accepted "E85 How to:" that we can follow? How does the steel gas tank and the 98'-02' fuel system stand up to the stuff?
    There are several threads on this forum which include most of the info you'd need to switch over to E85. I haven't had issues with my gas tank yet, but it is likely a good idea to change out the filter before you switch over, and then monitor it on occasion just to make sure it doesn't get clogged up. I have been running E85 for around 2 months now and haven't had issues yet (that I know of). haven't changed the fuel filter since changing it right before the "switch over" either.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  2. #2 Re: E85 afr
    Mar 2013
    Colorado - USA
    How did you do it? Give us the short and sweet version. What tables need attention?
    I feel like I could just open up the injector scale by 30% and be in the ballpark. I just cannot picture all of the consequences that will likely come from other tables.
    How do you like it? Did you drop a pulley or raise timing? Have you been to the dyno?
    I have a 1999 also (The Best year IMHO). With a 2007 cammed L32, a 2005 transmission, a 2003 PCM and the original 1999 fuel system and engine electrical. And she sets no codes and purrs like a kitty cat.
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  3. #3 Re: E85 afr
    Mar 2014
    Cincinnati, OH
    Ha, where to begin!
    http://www.grandprixforums.net/threa...re%27s+learned
    That is a short thread I put together on changing over and what can be addressed in the tune. A correction to the timing tables section: I would stick with stock timing and not add ignition advance personally. That has worked best for me and others have attested to the same thing.
    How do you like it?
    I LOVE IT!!!!!
    I got rid of a TON of KR (like 9* of KR... no joke) dropped a few pulley sizes as well
    Not yet but after I drop pulleys again within the next couple weeks, I am anxious to find out how much power it's putting down. Almost anyone who changes over seems to love it. shoot me a PM and I can help you with your specific tune. Should be able to set up a tune for you that will work well.
    ~Andrew
    2002 GTP sedan:
