So i started having this issue with my car getting high kr at low rpms. So i went and added some fuel cus i seen the cells in the 19.1 range and also lowered the timing in the cells a couple degrees. Now im having stalling issues and my car is all over the place at cruise so bad it will turn off my cruise control. It kind of feels like my tc but i think it just cus the fueling is to rich at those rmps. Im seeing pretty much perfect at wot 11.6:1. What should i see on average from the 7k range down? Im seeing codes p0131 and p0172 but i dont know if they are from the tune or actually the wires. The upstream is brand new denso. Also fuel pump and maf are new. Idle is really rough and has stalled twice so crank sensor also came to mind but i want som opinions on the tune befor i go that route. Thanks
Sorry forgot to mention codes are upstream low voltage and fueling to rich but both could be bad wire on o2 vac leak ect
