Thread: Which wideband should I get?
Results 1 to 20 of 23
  1. #1 Which wideband should I get?
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Or is the AEM UEGO the one to have?
    Planning on hooking it to an HP tuner through the removed egr and shooting for an e85 tune.
  2. #2 Re: Which wideband should I get?
    Oct 2011
    Puyallup WA
    Just bought a NGK and I love it
    08 G8 GT - exhaust Tune
  3. #3 Re: Which wideband should I get?
    SWPA
    Had a UEGO in the past, know several people who had one also, wouldn't go with anything else myself.
  4. #4 Re: Which wideband should I get?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    AEM or an Innovate MTX-L is what I would I would consider buying.
  5. #5 Re: Which wideband should I get?
    Arizona
    Ntk afx
  6. #6 Re: Which wideband should I get?
    uego here
    04 Comp G.
  7. #7 Re: Which wideband should I get?
    Topeka, KS
    Uego here too. However I rarely tune my car anymore.
  8. #8 Re: Which wideband should I get?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    UEGO here.. The AFX are nice too if you'd like a larger numerical display
    should be able to get a new UEGO on amazon/eBay for $160-$170
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  9. #9 Re: Which wideband should I get?
    Arizona
    I'd rather have a wideband that can be calibrated perodically . I don't why so many people get stuck on aem for widebands
  10. #10 Re: Which wideband should I get?
    Aug 2013
    McDonald PA
    Quote Originally Posted by 91parkave View Post
    Cause that's the only name they ever hear
  11. #11 Re: Which wideband should I get?
    Cost comes to mind, and they work for that price.
    Who cares about getting stuff exact, most people that tune cars are hacks anyway. So getting it within .2 to .5 of the AFR they want seem to work just fine or just run it slightly rich to save your ass.
    AEM's sensors do tend to read off slightly as they get older, but I'd replace it after 15k miles anyway to keep it fresh.
  12. #12 Re: Which wideband should I get?
    May 2013
    Upstate NY
    I just bought a plx. I haven't installed completely it yet but I really liked it so I bought it.
    04 CompG, black HAI, 180*, TR55s, custom tune by me, SD headers soon
    04 CompG, fusion orange, all stock
    99 GTP, red, coupe, 3.4, SLP exhaust, basic mods, PB 13.56, SOLD in 09.
  13. #13 Re: Which wideband should I get?
    Florida
    I have the plx setup and l love it. Had it for 7 months now and no problems. I also am using it to replace the stock o2 as well since it had a narrow output. The option to graph the signal on the digital screen was a big plus for me. If I'm driving I can watch the road and glance down at the gauge less often cause I see 2-5 seconds of data and can see dips or spikes.
  14. #14 Re: Which wideband should I get?
    May 2013
    Upstate NY
    Quote Originally Posted by Z34Phoenix View Post
    The narrow band simulation works well for you? My stock o2 is taking a dump and I was thinking of just putting the wideband in it's place and using the simulation. I've heard mostly good about that but a few guys say it sucks. I think I'll try it, then when I put my headers on I can change it if I don't like it.
  15. #15 Re: Which wideband should I get?
    Apr 2011
    Vassar, Mi
    I wouldnt use narrowband sim from any of the wideband contollers. one way or another I end up wiping out my wideband sensor once a year and it usually takes a few weeks (or months) to get around to replacing it. Using narrowband sim any time you have a issue with your WB you have an issue with your tune. Another thing is that widebands tend to fail slowly with a period of reading way off coming before total failure mode. During that type of failure it wouldn't be impossible for it to throw your LTFTs way off and leave you with -16.5 WOT ltft and possibly from there a chipped piston
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  16. #16 Re: Which wideband should I get?
    Arizona
    Another reason why people should buy widebands that can free air calibrate...even my LC1 setup @140 bucks with gauge is the same price as aem and its stillhamdlimg beautifully
  17. #17 Re: Which wideband should I get?
    May 2014
    Colorado
    Where are you guys putting the o2 for the wideband?
  18. #18 Re: Which wideband should I get?
    Florida
    I replaced my primary o2 and am using the narrow simulator feature of my wideband. That or have an o2 bung welded in on the downpipe.
  19. #19 Re: Which wideband should I get?
    Mar 2012
    NC
    I personally ran the Aeroforce wideband because I had the Aeroforce dual gauge setup. I enjoyed it and it worked well. I've installed the Innovate in two other vehicles. It also worked well. I think it's going to come from whatever gauge you like more or features.
  20. #20 Re: Which wideband should I get?
    Jun 2013
    Hollywood ,FL
    My aem one seems to be 1.0 off at times when hooked up to my buddys lap top our egr af reading is always 1.0 afr higher I hear thats common with aem tl not be accurate so lc1 has free air calibration?
  1. Which wideband to buy?
    By ADrugDealer in forum General Tech Discussion
    Last Post: 10-30-2012, 11:22 AM
  2. best wideband for ~$200?
    By z3r0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2011, 07:09 PM
  3. AEM Wideband o2
    By bbptech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2010, 04:23 PM
