Thread: Which wideband to buy?
Results 1 to 20 of 24
  1. #1 Which wideband to buy?
    May 2012
    Where winter never ends
    Back story: I had the innovate MTX-L wideband with a Bosch sensor. It died on me after three months. Long story short: Innovate would not email me back or contact me so I contacted Amazon Customer Service. The issued me a full refund for the unit. (Where I bought it)
    Now im stuck between a rock and a hard place. I need a wideband, but have no idea which one to buy. I am looking to spend around 199 for it if possible. Which one do you guys run/recommend. I am running E85 if it matters.
    2000 Regal - Winter Beater
  2. #2 Re: Which wideband to buy?
    Mar 2012
    NC
    Surprising you had issues with the Innovate. Those are typically pretty bulletproof. I've seen a bunch of people run that, the AEM, PLX, etc. I personally run the Aeroforce wideband. It works great, and I didn't need a separate gauge. As far as its accuracy, I haven't read anything that suggests otherwise that it is dreadfully inaccurate...it seems to be reading pretty spot on. Then again, I've only put 12 miles on the car since the build due to clutch/trans issues.
    Find the last wb thread i posted in
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I've got the AEM. It works great and was reading spot on when on the dyno.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  5. #5 Re: Which wideband to buy?
    May 2012
    Quote Originally Posted by Sushamouf View Post
    Sent from my Droid
    I am thinking about this one. Any issues with sub zero temps?
    May 2011
    United States
    I am not sure. Coldest weather it has seen so far is 30. I doubt it would have an issue though.
    Sent from my Droid
  7. #7 Re: Which wideband to buy?
    GTP Level Member AjL227's Avatar
    IL
    I have an AEM unit as well. I have put 30,000 miles on it in the last 2 years or so and it still works as well as when I got it new.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  8. #8 Re: Which wideband to buy?
    May 2012
    Quote Originally Posted by AjL227 View Post
    Awesome. AEM It is! Thanks guys. Off topic question for ya. Where did you get the SC belt tensioner in your sig?
  9. #9 Re: Which wideband to buy?
    Bad choice.
  10. #10 Re: Which wideband to buy?
    May 2012
    Bad choice.
    What would you pick then?
  11. #11 Re: Which wideband to buy?
    Ontario
    AEM has the best reputation by far. Cost definitely justifies the capability of the device. Not being able to buy a proper wideband is what made me put a halt on the installation of a turbo kit, need to be able to accurately see what's going on inside the engine.
    @Matt: Why is the AEM a bad choice? I thought you referred that to me? Everyone says the AEM UEGO is solid...
  12. #12 Re: Which wideband to buy?
    Really have to do this for you guys?
    I told you want to look for: http://www.grandprixforums.net/innov...sue-69931.html
  13. #13 Re: Which wideband to buy?
    Jan 2009
    Tallahassee, FL
    AEM here as well and it hasn't given me any hiccups, super easy to install.
    I did have an Innovative LC1 and I could never get that thing to work. From what I remember reading while trying to troubleshoot they're even picky on the power sources and grounds.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  14. #14 Re: Which wideband to buy?
    May 2012
    Quote Originally Posted by Sandman View Post
    I think Ill go with AEM, i like the reviews and the looks.
    @Matt I want a gauge not a box. From the reviews I have read the AEM UEGO is a very good gauge.
    And does anyone know where AjL227 got his tensioner? I havent ever seen one like that and am curious...
  15. #15 Re: Which wideband to buy?
    Quote Originally Posted by Adecker View Post
    Here is what you are not understanding. The AEM is crap and always will be crap for getting pretty much TRUE spot on numbers.
    It can be close but its always off compared to the AFX. The AEM gauge works, but just know its not as accurate.
  16. #16 Re: Which wideband to buy?
    SWPA
    AEM is the best bang for the buck. PERIOD!
  17. #17 Re: Which wideband to buy?
    I have an aem because it was cheap. He has a belt wrap setup
  18. #18 Re: Which wideband to buy?
    If you could recalibrate the controller to the aging sensor, and someone had verified the off stoich accuracy, then yes, it would be.
  19. #19 Re: Which wideband to buy?
    May 2012
    Dont get me wrong. I would love the AFX, only issue is its not a gauge...
    Quincy, Mass
    But it does have an analog output so you can attach it to a gauge. Plx makes a gauge or if you have an aeroforce you can hook it up to that and keep the box in the glove box
    No more GP 04 Impala SS Indy:
  1. best wideband for ~$200?
    By z3r0 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2011, 07:09 PM
  2. wideband 02
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 05:53 AM
  3. Wideband
    By GAFF in forum General Tech Discussion
    Last Post: 10-27-2010, 02:57 PM
  4. Wideband
    By TurboGTP in forum Turbo
    Last Post: 12-17-2009, 11:36 PM
