Thread: e85
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 e85
    Jul 2013
    adrian, mi
    Can you run an e85 mix with out needing to be tuned for it? Regular pump 93 is about 10% ethanol already so if you increase it to say about 20% can this be done Safely.
  2. #2 Re: e85
    Can you? probably but there wouldn be any reason to....
  3. #3 Re: e85
    Feb 2009
    flintnasty MI
  4. #4 Re: e85
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Been following your E85 posts Dark, thanks for keeping us posted. If I were to fill 3/4 with 93 octane premium, and 1/4 with E85, guessing my effective octane would be that much higher? (vs the 1/4 with 87 octane regular). Still think the stock injectors would be okay??
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  5. #5 Re: e85
    Dec 2012
    troll land
    E85 just seems like too much hassle to me
  6. #6 Re: e85
    Feb 2009
    flintnasty MI
    Quote Originally Posted by l67ss View Post
    pumping gas is so hard.
  7. #7 Re: e85
    Dec 2012
    troll land
    As in you have to plan routes around e85 stations. Ive seen guys miss car meets dues lack of e85 availability. No sugerwater for me thanks
  8. #8 Re: e85
    Arizona
    There life must be in ruins because they ran out of E85 stations.
  9. #9 Re: e85
    Dec 2012
    troll land
    I just like bein able to go on a trip and not have to plan around gas stations roflmao
  10. #10 Re: e85
    May 2012
    Where winter never ends
    There are octane calculators for mixing e85 with premium. Google it. Just be careful with out a tune. Trims can only do so much. And I would rather miss a meet and have e85 then go with out. The stuff is the best thing to happen to man kind and now POET (A leading manufacturer) can make the stuff out of anything that was once green and alive.
    2000 Regal - Winter Beater
  11. #11 Re: e85
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by Adecker View Post
    On that note, what would be recommended for me to change in my current tune to safely allows an E85 mix? Should I change target AFRs?
    2002 GTP sedan:
  12. #12 Re: e85
    May 2012
    You need to tune your MAF curve and fueling like you would for most anything. I adjusted my injector size by 30% to make it seem like they were smaller so they flowed more and then adjusted my maf curve and target afrs from there. Once your get your curve near perfect you can just set your targets. ALWAYS SCAN FOR KNOCK AND AFR.
  13. #13 Re: e85
    Mar 2014
    Cincinnati, OH
    Makes sense... not to thread jack, or change the intent of this thread, but why are the MAF curves necessary to change? I have done a ton of tuning on my current setup, but have never changed the MAF curve. AFRs on the wideband show up just fine and the car is showing extremely close to the target AFRs the ECU is commanding (which I set).
    Also, how do you adjust the injector size? what table is that in in the tune?
    2002 GTP sedan:
  14. #14 Re: e85
    May 2012
    When you get deeper into modding you'll have to start tuning your curve. Frankly I went from a 3.8 straight to a 3.2 and just tuned the maf. Me and frosty usually do either a wideband tune or a maf tune if no wideband is available.
    We have our wideband output wired into the EGR pintel position and we log that against the target and then adjust from there.
  15. #15 Re: e85
    Mar 2014
    Cincinnati, OH
    I see.. I guess one could change the commanded AFR, and/or the MAF curve and achieve the same result?? increase the MAF curve to "trick" the ECU into believing it is seeing more air than it really is to get some additional fuel?
    How would you recommend changing the MAF calibration for an E85 setup or E85/regular mix? Just scale the entire curve up?
    2002 GTP sedan:
  16. #16 Re: e85
    May 2012
  17. #17 Re: e85
    May 2012
    No, you scale the injectors back 30% and then do a maf tune
  18. #18 Re: e85
    Mar 2014
    Cincinnati, OH
    I will have to take a look at that HP Tuners thread to check out MAF tuning. No intent on rigging anything. Guess I just need to better understand what scaling back injectors really involves and how it works.
    I have hoped/planned on switching over to E85 at some point all along. Been looking for a good set of used 42.5 or 60 lb injectors for the changeover. Hence why I really need to learn how to scale and tune for injector changes.
    2002 GTP sedan:
  19. #19 Re: e85
    May 2012
    What are your power goals?
  20. #20 Re: e85
    Mar 2014
    Cincinnati, OH
    300whp daily driver is the hope. I figured intake/exhaust, rocker, and a good E85/pulley swapped car would be capable (including fuel system upgrades) with the tune dialed in.
    2002 GTP sedan:
