Thread: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
Results 1 to 7 of 7
  1. #1 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    SE Level Member camaromattcaddy's Avatar
    Jul 2013
    Medina, Oh
    Hey guys my Daytona 500 GTP was totalled a while ago and being that I had a Fiero laying around waiting for a 3800 sc I guess now is the time. I am not looking for crazy crazy power. I can tell you the upgrades I already have and I am just looking for ideas and what kinda upgrades I would need. The car already had the colder t*stat, the plog, ngk iridium plugs, There will be no U-Bend obviously and I will probably be running 3" exhaust the whole way out. I am realistically looking for a 2.8 or maybe a 2.6 pulley. I know I will have to get at least a cam and maybe rockers. Please just let me know what else I would need. I will be using HP Tuners on the car so everything will be custom. I am just trying to avoid detonation and make my car run somewhere in the 11's.
  2. #2 Re: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    Think E85 and a intercooler if you want that low of pulley without real problems.
    Stick to a 3.0 to 3.2 size pulley with cam and it will be plenty fast.
  3. #3 Re: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    Jul 2013
    Medina, Oh
    so what kinda supporting mods would I have to do. Knock retard wont be a problem with the fiero exhaust and I will be doing my own tuning. what would be the best route.
  4. #4 Re: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    Feb 2009
    flintnasty MI
    Pace setter style headers are the best ive used in fiero swaps. Other than that intercooler and xp cam is all you need for 11s.
  5. #5 Re: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    Jul 2013
    Medina, Oh
    so with the XP cam should i just run factory rocker arms or should I try to raise the ratio
  6. #6 Re: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by camaromattcaddy View Post
    factory for sure is my opinion. Only time you raise the ratio is when you're not going to take the time/cost/effort to do a cam. The cams are designed to make good power in the right way just how they are. No higher ratio arms required!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  7. #7 Re: 3800 Supercharged swap into 1988 Fiero tuning and upgrade suggestions.
    Jul 2013
    Medina, Oh
    I am guessing you have used HP Tuners then to work with on your car. What kinda tips would you have. I used it before on a basically stock gtp. what stuff should I do with one modded the way we were talking about
  1. can i swap a 3800 sereis 2 with the supercharged engine
    By lilrooks21 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-31-2013, 12:38 PM
  2. fiero 3800 swap
    By Juanmiguel in forum PCM Tuning
    Last Post: 02-13-2012, 11:02 AM
  3. My latest 3800 S2 supercharged swap
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 10-10-2011, 12:32 AM
  4. 3800 s/c fiero swap
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 07-29-2010, 11:40 AM
  5. Supercharged 3800 swap
    By biggz in forum General Tech Discussion
    Last Post: 09-06-2009, 03:07 PM
