Quote Originally Posted by camaromattcaddy View Post
so with the XP cam should i just run factory rocker arms or should I try to raise the ratio
factory for sure is my opinion. Only time you raise the ratio is when you're not going to take the time/cost/effort to do a cam. The cams are designed to make good power in the right way just how they are. No higher ratio arms required!
