Thread: help with knock?
Results 1 to 16 of 16
  1. #1 help with knock?
    GT Level Member natethegreat's Avatar
    Brookings, SD
    Doing some full throttle runs and i logged it with the tourque app. I have zero knock in first but it shifts to second waits a second than i start getting knock. 4 degrees most of the time. Said 7 once. First i thought i was just because of the shifting but now im not so sure. Also, i don't know how to attach the log. Any thoughts?
  2. #2 Re: help with knock?
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    mods? stock gps have knock so if your stock thats why
  3. #3 Re: help with knock?
    Brookings, SD
    Sorry, i should be more specific. I've got a top swap running stock pulley and headers. Had tuned in car, not just a canned tune.
  4. #4 Re: help with knock?
    Florida
    when you had the in car tune, did you do any runs in 2nd gear? also i feel you prob need more mods to run a stock pulley on a topswap. I have ported heads and a ported blower, headers, full exhaust, ported TB, and many hours of tuning to get things dialed in perfect. its possible you need more fuel and or more mods.
  5. #5 Re: help with knock?
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Yeah, if you're running a stock top swap setup, it would be wise to go up in pulley size a little unless you're doing more mods soon.
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  6. #6 Re: help with knock?
    Brookings, SD
    I didnt personally tune it, but he did do runs in each gear..if need be ill swap to a larger pulley, but I just thought its odd I have no knock in first, but s decent amount of knock in second. Where can I find a larger pulley?
  7. #7 Re: help with knock?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Intense, ZZP, WBS do you have a MPS or stock stock press on? Also what were the temps when you got it tuned? Warm weather would give more knock.
    Sent from my Galaxy Tab 3 8.0
    2012 F150 STX
    - Gonna be a race truck
  8. #8 Re: help with knock?
    Brookings, SD
    Stock press on. 50-60 degrees i believe
    60-105mph, intake temps were around 105, outside temp was 50 degrees.
    There were some other runs but they were similar. Still have like no knock in 1st gear.
  9. #9 Re: help with knock?
    SE Level Member a97GTP's Avatar
    Jul 2013
    Priest River, Idaho
    Id run a bigger pulley, I went top swap a while back and had to do more flow mods than that To stop knock.
    Try running a step colder plugs also. I ran AL104's
    Black 1997 Pontiac Grand Prix GTP, 3.4" Pulley, P&P Supercharger, Modified LIM, VS-Cam, 105# Springs, FWI, Ported Rear Manifold, ZZP P-LOG, EGR Delete.
    ^^^L36 Top Swap^^^ R.I.P. L67 197,894
  10. #10 Re: help with knock?
    Brookings, SD
    I think im running 104's now. What flow mods do i need to do? And can someone please link a 4.00 pulley, i cannot find one at any of the stores.
  11. #11 Re: help with knock?
    Howell, NJ
    I would email zzp. They have the pulleys included for top swap kits. I just don't see them in the individual pulley page.
  12. #12 Re: help with knock?
    Apr 2012
    Dayton, OH
    Why are your IATs so high? I would talk to who tuned it for you. You should pick up a MPS so you can change pullys easier and a 4.0 pully which is equal to a 3.8 on a top swap car iirc so a 3.8 on a top swap is like a 3.6 or 3.5 on a GTP.
    Sent from the Milky Way
    2012 F150 STX
  13. #13 Re: help with knock?
    Brookings, SD
    I couldnt tell you why they were so high. Im running just an open cone on the TB. The runs were also after sitting and getting fuel. Also running on 92.
  14. #14 Re: help with knock?
    Where do you see his IATs at?
    -edit- nevermind i see he posted it.
  15. #15 Re: help with knock?
    Apr 2012
    Dayton, OH
    He said they were about 100 so im going off that
    2012 F150 STX
  16. #16 Re: help with knock?
    If I'm reading that right it looks like you need to add timing.
  1. what is rod knock
    By pontiacgtp98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2012, 07:13 PM
  2. rod knock or something else?
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2011, 09:46 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
  5. How much knock is ok
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2009, 05:35 AM
