Thread: Still getting knock with 3.8" pulley and exhaust mods
Results 1 to 20 of 22
  1. #1 Still getting knock with 3.8" pulley and exhaust mods
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    Recently installed K&N intake, PLOG, and ZZP 3" Catless DP on my 1999 GTP. There are no vaccuum leaks or anything like that and I replaced all the vac/boost lines to be sure. I have a lower temp T-Stat and the stock 3.8" supercharger pulley. Did some data logging yesterday and I am still seeing ~2 to 3 degrees of KR at WOT at different places in the RPM range. Anyone know why this is the case? Have you seen this regularly on stock GTPs with exhaust mods?? Figured I would have 0 KR after those mods without running more boost...
  2. #2 Re: Still getting knock with 3.8" pulley and exhaust mods
    Nov 2011
    NY
    It happens... New plugs? Wires?
  3. #3 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by coolone View Post
    New ZZP 10.5mm wires. Not new plugs. I have AL104s to put in though. bad to run those without added boost though??
  4. #4 Re: Still getting knock with 3.8" pulley and exhaust mods
    If this was the HP Tuners website, I'd say post the tune and scan so we can take a look at it.
    But you can't paste those on the this forum. Without seeing the tune, there isnt anything I can do to suggest.
  5. #5 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    Understandable. The tune is pretty much stock as far as AFRs go, PE tables, MAF, etc.
    LTFTs are a consistent +3.1% under WOT...
  6. #6 Re: Still getting knock with 3.8" pulley and exhaust mods
    May 2008
    Schuyler, NE
    Not that uncommon. I'd switch to e85 or intercool it.
  7. #7 Re: Still getting knock with 3.8" pulley and exhaust mods
    I'm sure if he lowered the timing by 2 degrees to around 13-14, most of it would be gone.
  8. #8 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    True. I haven't seen the timing go below 14.5 with my KR and that was shifting at 5,750 rpm.
  9. #9 Re: Still getting knock with 3.8" pulley and exhaust mods
    Arizona
    Why wouldn't you add a little more fuel for your pe and see if the knock goes away first
  10. #10 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by 91parkave View Post
    Think I should try that even though it's a stock pulley? I was under the impression they run them a little rich from the factory. Guess it would be a quick change though in the PE table and see how it works.
  11. #11 Re: Still getting knock with 3.8" pulley and exhaust mods
    Oct 2011
    Puyallup WA
    Stock tune 3in dp and stock pulley I saw up to 5 degrees of kr I wouldn't worry about it
    08 G8 GT - exhaust Tune
  12. #12 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by wa04compg View Post
    Did you do anything to get rid of it? Think it is worth me dropping pulley size if I am already seeing KR with the stock pulley?
  13. #13 Re: Still getting knock with 3.8" pulley and exhaust mods
    Oct 2011
    Puyallup WA
    I would tune out your kr first before you think about dropping a pulley...was just making a point that stock tune stock gtp tend to have kr pretty normal it seems...flow mods may or may not make them go away
  14. #14 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    Good deal. Thanks for the info!
  15. #15 Re: Still getting knock with 3.8" pulley and exhaust mods
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    My stock 97 when I first had it, saw upwards of 7*+ of KR from the factory. Seeing you only have 2-3* after a PLOG/DP combo, seems not to out of the ordinary. Add a little fuel and see if that cures the issue. I'd also replace the plugs as well. Since you're on a stock pulley, run AL606's since thats stock heat range. You want the hottest spark possible. When you drop pulley sizes, then swap to AL104 or even AL605's.
  16. #16 Re: Still getting knock with 3.8" pulley and exhaust mods
    Oct 2011
    Puyallup WA
    I run al605 on my header rocker genv 3.5 and have been great so far
  17. #17 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    As of this afternoon, just saw up to 5.7* KR at WOT around 5,300 RPM.... Target AFR is 12.2 (set by me) in the PE table. I still need to swap plugs to see if that helps but gosh, 5.7* ?!?!?! Fuel trims are zero all the way across. Can plugs get rid of ~5* of KR? Maybe I should target lower AFRs in my PE table??
  18. #18 Re: Still getting knock with 3.8" pulley and exhaust mods
    Oct 2011
    Puyallup WA
    Do you have a wideband? Afr should be lower then that...most guys on here shoot for 11.2ish I think
  19. #19 Re: Still getting knock with 3.8" pulley and exhaust mods
    Is that the target plus the add vs time/rpm??
    Because then it would go richer to around 11ish.
  20. #20 Re: Still getting knock with 3.8" pulley and exhaust mods
    Mar 2014
    Cincinnati, OH
    That's just target. I left the stock adder vs. time/RPM alone.. I'm tempted to zero out that table and make the target lower. Going to change plugs this afternoon and change the target and see how it does.
  1. "Tune up" performance, exhaust, possible mods and Seafoam?
    By CycoPuppet in forum Introductions/Noob Questions
    Last Post: 09-14-2014, 05:51 PM
  2. Still getting knock with 3.8 pulley and exhaust mods...
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 03-31-2014, 08:50 AM
  3. Getting knock w/ 3.4 pulley & All suported mods
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-05-2010, 11:13 PM
  4. Supporting mods for 3.4" - 3.2" Pulley
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-26-2008, 12:33 PM
