Thread: AFR and Timing Tuning (02 Regal GS 223k!!!)
Results 1 to 20 of 92
  1. #1 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    You need to have that wideband in the right place before you try and make changes or else its useless
  2. #2 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Quote Originally Posted by 91parkave View Post
    How is it useless if the front cylinders are the problematic poppers?? Most header company's put the bung in the crossover right before it meets the rear bank. Like W-Body Store for the actual 02 sensor so it only reads off the front. Unlike factory you get front and rear all in one. Yes you could crawl under the car and put it in downpipe exit but why if there is an easy access above?
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  3. #3 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    Arizona
    Quote Originally Posted by PWNED View Post
    Dude any wideband instructions and/or installs you see never have half of the engine to accept that as the engine AFR reading. Wbody store just did that for a unknown reason
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. Pulley / Timing / MAF tuning with elevation change
    By Impala131 in forum PCM Tuning
    Last Post: 02-21-2013, 04:15 PM
  3. 1998 Regal GS Tuning Question
    By DrGSXR750 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 04:38 PM
  4. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
