Thread: AFR and Timing Tuning (02 Regal GS 223k!!!)
Results 1 to 20 of 92
  1. #1 Re: AFR and Timing Tuning (02 Regal GS 223k!!!)
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Those numbers are probably fine. if you plan on using a narrowband, I would use that to tune in the IFR numbers better.
    General "afr at wot" tuning will be done in your PE tables.. pick your poison there it really doesnt matter. This will change your requested afr (which I noticed you are not scanning, why?)
    LQ4 is a nice maf, no reason to ditch it really. Make sure you have the "right" LQ4 table out there and go for it. I cant really gauge from your posts what maf table you are currently using.
    What is this requested afr you speak of not in the scan? Is actual not ok when the wb is hooked up? In the table it is displayed as seen. I am trying to un-hack tune the car but there is not an actual lq4 maf file in the pcm as I asked the previous owner. He just modified the stock file to work. It looked like a roller coaster. It is much better looking now. I am not flowing 11500 plus so I really see no need for this lq4 or any gains it would give me. Right?
    Also how am I hitting 10500 hz on tis setup? My gtp was on spray/cammed and hitting 10,000hz at times seen here.
    http://www.grandprixforums.net/showthread.php?t=51024
    But why use NB to tweak the IFR's? I mean if I have the WB hooked up that is the best unless I misunderstood.
    Would shrinking my 104s from .054 to .050 net me any possibility to add more timing?
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  1. double timing vs stock timing chain
    By Dam20735 in forum General Tech Discussion
    Last Post: 05-24-2013, 12:53 PM
  2. Pulley / Timing / MAF tuning with elevation change
    By Impala131 in forum PCM Tuning
    Last Post: 02-21-2013, 04:15 PM
  3. 1998 Regal GS Tuning Question
    By DrGSXR750 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2010, 04:38 PM
  4. Got another timing???
    By GTP4 in forum PCM Tuning
    Last Post: 11-15-2008, 07:38 PM
