Thread: Older power tuner (1.2.3e) and UVScan download?
Results 1 to 11 of 11
  1. #1 Older power tuner (1.2.3e) and UVScan download?
    May 2012
    Albuquerque, NM
    Hello y'all! I was wondering if one of you could either email me the .zip file or point me to a link. I used the link I had but it was PT 1.2.4 and the UVScan was corrupt. I really need to find a more reliable scanner than 1.2.4 as it usually corrupts the files when saving it.
    Any other ideas?
  2. #2 Re: Older power tuner (1.2.3e) and UVScan download?
    PM me your email addy
  3. #3 Re: Older power tuner (1.2.3e) and UVScan download?
    May 2012
    Albuquerque, NM
    I was given one link and found one link. I will only post the link I found through google that contains PT 1.2.3e
    https://www.dropbox.com/sh/rdqb3t14drfsqa3/NiZrTqFaeb
    Thank you BillBoost for your help as always.
  4. #4 Re: Older power tuner (1.2.3e) and UVScan download?
    May 2012
    Albuquerque, NM
    So, I have found the UVScan but I have not been able to install it. I'm by no means an idiot with a computer but I cannot get it to load, or run in any fashion, I MUST be missing something. Please help me understand my obvious mistake. I need the UVScan as my PT 1.2.3 and 1.2.4 are both giving me bad files while scanning.
  5. #5 Re: Older power tuner (1.2.3e) and UVScan download?
    Florida
    Im not sure what version of uvscan you have. I have two different ones. one is labeled 10-18-08 and the other is UVSCAN3. uvscan3 is junk. i could not get it to work properly. i have not tried that uvscan2 in that drop box maybe i'll look at it and see.
  6. #6 Re: Older power tuner (1.2.3e) and UVScan download?
    May 2012
    Albuquerque, NM
    That is the only one I have access to. Would you send me a copy of the working copy you have? Please? :-)
  7. #7 Re: Older power tuner (1.2.3e) and UVScan download?
    Florida
    What is your email?
  8. #8 Re: Older power tuner (1.2.3e) and UVScan download?
    May 2012
    Albuquerque, NM
    Pm sent... Thank you sir.
  9. #9 Re: Older power tuner (1.2.3e) and UVScan download?
    NY
    Sorry to get off topic but I've got all three versions of DHP and what's the pro's and con's on 1.19/22/24?
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  10. #10 Re: Older power tuner (1.2.3e) and UVScan download?
    Florida
    IIRC before 1.2.4 the software was locked to the original engine type requested when originally ordered. Most people got their DHP's second or third hand by now. I am the original owner of mine. when i bought mine they just started offering 2 engine types that the tuner would work on. If you were to use 1.1.9 I know that you will not have full access to all different engine types as far as saving and flashing. Version 1.2.2 introduced the ability to perform partial writes and will allow real time writing of scan data. as said before, 1.2.4 unlocked all the engine types. also with each data base update more support was added. there is also a database update that was never included with the above versions. it allowed me access to TCC and gear ratio settings on my DOHC engine. I am not sure what else it can do but was very handy.
  11. #11 Re: Older power tuner (1.2.3e) and UVScan download?
    NY
    Good to know, I forgot about the other versions being locked it's been so long.
  1. UVScan
    By Lawngoose in forum PCM Tuning
    Last Post: 10-09-2011, 08:30 PM
  2. power tuner help
    By 97redrocket in forum General Tech Discussion
    Last Post: 04-07-2010, 07:39 PM
  3. New power tuner
    By Deeter in forum PCM Tuning
    Last Post: 05-26-2008, 09:32 AM
