Thread: DHP v1.0 ststststutter @ 4500rpm in 2nd.
Results 1 to 7 of 7
  1. #1 DHP v1.0 ststststutter @ 4500rpm in 2nd.
    Oct 2013
    Dayton, Ohio
    I'm not good with this kind of stuff. Hope you guys are. I can not provide any vitals, ie KR, boost, trans temp etc. I can provide the basics.
    1998 GTP, 119k. rebuilt charger.
    HAI
    160* t-stat
    temp gauge showing 170 at the time of the "run."
    a mix of 93 and 91 octane (couldn't find 93 when I wanted to get gas.)
    Perf. Shift ON
    TCS OFF
    Purchased a PCM tonight thats carrying DHP v1.0. The numbers on the outside correspond directly to those found on my stock pcm. Car runs AWESOME EXCEPT at ~4500rpm in 2nd gear during a WOT pull. It quickly stutters for <1sec and then seems sluggish through the rest of the "run." The car kind of feels like it's falling on it's face. Almost feels like a timing issue. I haven't run it through it's paces (WOT) into 3rd yet.
    Any thoughts?
  2. #2 Re: DHP v1.0 ststststutter @ 4500rpm in 2nd.
    Feb 2009
    flintnasty MI
    DHP pcms usually run richer, which will stress your ignition system.
  3. #3 Re: DHP v1.0 ststststutter @ 4500rpm in 2nd.
    NY
    Did you do a case learn after installing the pcm? It's a must most of the time. You could be getting kr that your not seeing cause your not scanning.
    2001 Regal-GMPP handling, shift kit, tuned, ported Gen3, 3.6, N*, SLP dual catback, Aeroforce
    70 Monte Carlo 12.5@109 waiting on new setup
  4. #4 Re: DHP v1.0 ststststutter @ 4500rpm in 2nd.
    Oct 2013
    Dayton, Ohio
    By case learn, do you mean disconnecting the battery for 25-30 minutes? If so, yes I did. If that is not the procedure, please share.
  5. #5 Re: DHP v1.0 ststststutter @ 4500rpm in 2nd.
    Florida
    IMPORTANT: If you are installing a reprogrammed PCM, make sure to take the car to the dealer to get the crank sensor position (or CASE) learned. This is not required for 1997 GP PCMs because the data is already stored in the knock sensor you switched above. You may get a "Service Engine Soon" lamp after the installation - this is due to the CASE learn not having been performed. Whether you get the SES light or not, you should still get the CASE learn procedure performed. Any GM dealer or official service shop can do the procedure if they have a Tech2; they may charge you a nominal fee for the service. In brief, here is a description from the GM Service Manual:
    The crankshaft position system variation learning feature is used to calculate reference period errors caused by slight tolerance variations in the crankshaft, the crankshaft balancer interupter rings, and the crankshaft sensor hall effect switches. The calculated error allows the PCM to accurately compensate for reference period variations. The crankshaft position system variation learning feature enhances the ability of the PCM to detect misfire events over a wide range of engine speed and load.
    Need to either take it to a dealer, or have someone with a tuner do it for you.
  6. #6 Re: DHP v1.0 ststststutter @ 4500rpm in 2nd.
    NY
    Case learn is important if swapping pcm's. Like posted above go to the dealer or find someone with a tuner and they can case learn the car. I'd suggest staying out of the throttle though till.
  7. #7 Re: DHP v1.0 ststststutter @ 4500rpm in 2nd.
    Oct 2013
    Dayton, Ohio
    will do! Thanks guys.
  1. Unresponsive 3.8 Liter Acceleration and Strange Sound at 4500RPM
    By HWYSPEEDER in forum General Tech Discussion
    Last Post: 05-15-2011, 11:29 AM
