ill try to see if theres anyone local to the boston area with a tuner.
as for the HUD ill pull it apart anc check connections when i get a day off from work.
and for the tire issue ill put it back down to normal psi tomorrow morning and see about getting 2 new tires for the front and use the passenger side as a full size spare if i can find a 17inch rim.
also need to buy a new RCA cable because my sub hits when it wants to and im leaning towards that being the issue since i just fixed all the wires and swapped the head unit.
thanks for the help!!
