Thread: Complete new build and I need to tune it
Results 1 to 19 of 19
  1. #1 Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    Ok so I've got a 04 GTP Comp G and I recently destroyed the motor racing a new charger (I won until I got to the end of the interstate and heard that awful yet familiar knocking). I preceded to look for a junkyard motor and the only ones I could find in the area were from N/A cars so I said screw it I'll make it work. I have since bought said engine, tore it down to bare block and cleaned it and replaced all the seals, oil pump, timing chain and tensioner. I also bought the short stack intercooler kit from ZZP, pacesetter headers with 3" high flow cat, autolite 104's, 180* thermostat, and a 3.4 inch pulley. All this has been installed and its ready to go but I sent my computer to PCM of NC to have it tuned and it turns out they cannot tune it due to the fact they don't have a file on hand of a similarly modded car. Rather than pay the $600 plus for a dyno tune I had the idea of buying HP tuners and getting a flash from someone on here with similar mods and then flashing it to my car and researching how to tune and then tweak the flash to fit my car therefore I'm spending about the same amount but in the process I get HP tuners and learn a new skill. Any thoughts, comments, advice, .02 and help is much appreciate
    Dylan
  2. #2 Re: Complete new build and I need to tune it
    GTP Level Member tms8582's Avatar
    Washington Michigan
    I think it would be cool to learn the ins and outs of tuning but i bet zzp or intense could get you a decent mail order tune. Did you use the l32 cam? If so all that's really changing is your na block has more compression. I'd give John a call at intense. I bet he has done a dozen pcms with your exact setup. I'd guess the ss intercooler and headers a will allow you to run that 3.4 no problem.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  3. #3 Re: Complete new build and I need to tune it
    Florida
    No. A 3.4 o. A topswap is like running a 3.0 on a normal engine. Headers and ssic will prob let u run a 3.6.... Maybe. If you have rockers or a cam the 3.4 might be ok, but I would not trust a mail order PCM to do the job.
  4. #4 Re: Complete new build and I need to tune it
    Nov 2011
    NY
    Thoughts are this... Put the 3.8 back on till tuned. If you're gonna play around with it, continue modding, etc., then HPT is a worthy investment cause the boxed tune is half way there ($).
    HPT site, here and many other resources to get you going with tuning. You should start with a base file anyway and then a weekend (for noobie) of driving and adjusting will get ya your own tune. Starting stock and working down to what pulley you want, always adjusting for the ever engine killing knock. With a boxed tune you may still have knock, then what?
    Only and best way to go is in car tune.
    my $.02
  5. #5 Re: Complete new build and I need to tune it
    I would run a 3.8 until you get it tuned first. Your in NY I'm sure there's quite a few guys that can still tune within your area. Maybe meanwhile get a mail order PCM and not beat on the car.
    04 Comp G.
  6. #6 Re: Complete new build and I need to tune it
    GTX Level Member blackflag's Avatar
    Virginia
    sell the ssic, get a s2ic. run the 3.4
  7. #7 Re: Complete new build and I need to tune it
    Feb 2009
    flintnasty MI
    Stock pcm should work fine.
  8. #8 Re: Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    Concerning the cam, I used the one that was in the n/a block. I got on rock auto, oreily's, and researched as much as I could and the cam in the L26 and the L32 are the same. Also I finally got car completed today and took it for a short spin and if i get into any boost or accerate lightly to above 3000 ish rpm it misfires. Is that due to not being tuned or could I be running too cold plugs?
  9. #9 Re: Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    Also how do I find someone on here who's in or near NY that I could persuade to come tune or help me tune my car?
  10. #10 Re: Complete new build and I need to tune it
    Florida
    OMG! you are running a topswap. stock NA pcm will destroy that engine in no time. even at 3k you prob are seeing boost and it is detonating.
  11. #11 Re: Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    I'm using the L32 pcm. And I havent run the car far. basically about a mile from the shop to base housing.
  12. #12 Re: Complete new build and I need to tune it
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Z34Phoenix View Post
    Uh. No... stock will work fine the pulley is likely. a bit small
  13. #13 Re: Complete new build and I need to tune it
    Nov 2011
    NY
    The stock PCM does not account for fueling with the added boost... So you'll be FINE, unless you introduce something to the engine the PCM is unable to adjust for, namely higher rpm/boost. Keep at it and you'll be looking for a new engine, one mile or two blocks, don't matter. You'll be tempted again to hit the throttle, then BOOM!
    Are you even monitoring for knock? Come on... You've researched the cam, but nothing else? Spent all that money on the build but don't want to pay for a tune (dyno) even if that's all that is available to you?
  14. #14 Re: Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    I know the tune is vital. I just need to find someone to do it. I actually am in SC right now but I'm moving to NY this saturday so I dont know anyone in NY. If someone told me a way to find someone who knows how to tune in NY I'd gladly pay. And I will be monitoring for knock. I'm ordering this to allow me to see everything on my phone. Seems like a nifty little device
    http://www.scantool.net/obdlink-mx.html
  15. #15 Re: Complete new build and I need to tune it
    GTP Level Member
    Pittsburgh
    I would sent it to someone who knows what they are doing...I wouldnt trust someone that "didnt have a file"
    or depending where you are in NY, come over to Pittsburgh and ill Tune it, for the cost of credits
    2003 SSEi,
  16. #16 Re: Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    2003 SSEi I might hit you up on that. Ill be coming through there on my way to NY. Would you be free sometime around the end of Oct?
  17. #17 Re: Complete new build and I need to tune it
    Feb 2009
    flintnasty MI
    Quote Originally Posted by whiz92 View Post
    A tune is not "vital". What you have now will work fine unless you have too much pulley on it for your setup, which you probably do.
    This could not be more wrong. The PCM does not read "boost", it reads air, and a stock PCM can read up to at least 20% more air than stock without modifications. With some "tricks" you can push that number even further.
  18. #18 Re: Complete new build and I need to tune it
    Banned
    CT
    I can hook you up, come down to CT.
    I've seen ~150 of these cars on the tuner, not 1 engine has blown.
  19. #19 Re: Complete new build and I need to tune it
    Oct 2013
    Ballston Spa, NY
    Snowflake - How much would you charge for a tune?
  1. kung fu panda (e85 with 2.8 )SOLD
    By TEK310 in forum Members Rides
    Last Post: 04-18-2014, 08:40 AM
  2. e85 Dyno Tune at Dyno Tune Motorsports - Video
    By tms8582 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2013, 07:57 AM
  3. tune vs no tune. safe?
    By hollas13 in forum General Grand Prix Discussion
    Last Post: 07-09-2013, 07:54 AM
  4. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  5. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
