Thread: dhp pcm
Results 1 to 8 of 8
  1. #1 dhp pcm
    GT Level Member al2000gtp's Avatar
    Buda,IL
    Mine should be here tomorrow from 3800 performance for my 2000 gtp. Is there any special install or is it as simple as disconnect battery, install new pcm, and connect battery again? Also is a case learn required?
    2000 GTP - HAI, SD Headers, 3" catback, cat delete, thrush turbo muffs, self ported sc, and transgo shift kit.
  2. #2 Re: dhp pcm
    seems the need for a case learn is a 50/50 chance. from what ive read with people getting caned tunes.
  3. #3 Re: dhp pcm
    Buda,IL
    Thanks scotty
  4. #4 Re: dhp pcm
    Buda,IL
    Alright installed pcm today and it threw a p1336 code so I need a case learn. Is it bad to drive it like this until I can get it to the dealer tomorrow as long as I take it easy on it
  5. #5 Re: dhp pcm
    if its running good id think your ok for a day.
  6. #6 Re: dhp pcm
    Buda,IL
    I haven't driven it yet cuz I was nervous to with the code but it fired right up and idled fine for bout 10 mins. Thanks again for the help scotty
  7. #7 Re: dhp pcm
    You'll be ok driving like that
  8. #8 Re: dhp pcm
    Buda,IL
    Yeah car ran fine. Got it to the dealer today and was in and out in 15 mins and only cost me 20 bucks.
    Got into the throttle on the way home and still seeing knock at the top of 2nd gear but came on later than it did before. Used to see 1 to 2.8 around 65 and now its around 75-80.
    Makes me a little nervous cuz im still on stock pulley. Time to take care of the shotty rear suspension and I think I have a vac leak somewhere cuz my ltft like to hang out around +12 at idle. Thanks again guys for the responses
