Thread: Help me get my idle right!
Results 1 to 9 of 9
  1. #1 Help me get my idle right!
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    2005 GP L26, Gen V, L32 heads. S2X cam.
    The car was dyno tuned with a short street tune after that and runs GREAT but has trouble idling, (surges and stalls out at every stop) I has the idle set to 950 and it was fine but I think that is a bit high. Id like it around 750-800 if that is possible. Any tips or ideas I should give my tuner? I am going back up there this weekend for him to try and sort it out...
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  2. #2 Re: Help me get my idle right!
    Feb 2013
    37.295091, -121.930053
    sounds to me it needs someone that has tuned GP's before
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Help me get my idle right!
    Apr 2012
    Middletown DE
    no knock and 25mpg highway, Id say hes 90% there. He's a specialist with German cars and LSx cars. He actually tuned the car that holds the time record for the fastest stock bottom end LSx car.
    1993 Oldmobile 88
  4. #4 Re: Help me get my idle right!
    25 mpg? It should get better than that. You sure you don't have a vacuum leak?
  5. #5 Re: Help me get my idle right!
    Apr 2012
    Middletown DE
    Highway speeds around me range 80-85. The boost gauge seems normal for vacuum. Butt ill give it the old carb cleaner test.
    1993 Oldmobile 88
  6. #6 Re: Help me get my idle right!
    May 2008
    Schuyler, NE
    Also sounds to me like you've got a vac leak.
  7. #7 Re: Help me get my idle right!
    Apr 2012
    Middletown DE
    The tuner said my IAT numbers were off and that it could be resolved by drilling a small hole in the throttle plate. Which I did which seems to have helped a bit. Would my PCV being blocked by the intercooler core have anything to do with this?
    1993 Oldmobile 88
  8. #8 Re: Help me get my idle right!
    Feb 2009
    flintnasty MI
    s2x is going to push a bunch of air at idle, and probably max your trims out. You also will want to run ~40 degrees of timing at idle.
  9. #9 Re: Help me get my idle right!
    Apr 2012
    Middletown DE
    I was going to go back up there this week after work, but I ordered the Devils Own Meth kit.. Ill add that, put my 3in pulley on and then go back up there.
    1993 Oldmobile 88
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  3. Running rich at idle, causing idle issues.
    By matt5112 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-22-2010, 09:16 PM
  4. idle
    By kylehendy79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-07-2010, 06:21 PM
  5. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
