As far as the spark plug non fouler, basically it's just a metal tube which I thread into the exhaust pipe O2 hole, then thread in the O2 sensor on the other end right? Are there different lengths or what? I get the P0420 code after getting a Magnaflow Cat & 3'' Downpipe. Was wondering if maybe this could help a little. I'm trying to do a few small things before I have to bring it into a shop to figure out my high rpm misfiring and small idling issues. I'm going to try to seafoam first to see if that helps at all and find any leaks if there are any.
I looked up the downstream, it's an 18mm. So will this work? http://shop.advanceautoparts.com/web...on+fouler+18mm
Also, I'm getting code P0036 (Heated Oxygen Sensor, Heater Control, Circuit Bank 1, Sensor 2) I tested the heater resistance and it was about 8 Ohms. From what I read up on, that is about right. Any suggestions?
As far as the seafoam goes, I can just use the brake booster vacuum hose line for adding in the Seafoam slowly while someone holds the gas down aroun 2500rpms right? Then shut it off and leave it alone for 10~15min then start up again?
