Thread: Aem wideband completely innaccurate
Results 1 to 17 of 17
  1. #1 Aem wideband completely innaccurate
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    I'm using an AEM UEGO 30-4100 with the PID recommended.
    I have it wired to my egr position wire....
    The numbers are way innaccurate. It pretty much sits @ 14.9 on HPT but moves all over on my AEM gague.
    Anyone else have this issue?
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: Aem wideband completely innaccurate
    Did you check HPT site for the pid setup? I saw that you were unsure about the pid you used.
  3. #3 Re: Aem wideband completely innaccurate
    May 2008
    Schuyler, NE
    Sounds like your formula is incorrect.
  4. #4 Re: Aem wideband completely innaccurate
    Oct 2012
    New Jersey
    I'm using ([PID.2811]*2)+10 which was in the thread.
    I will check hpt forums again though.
  5. #5 Re: Aem wideband completely innaccurate
    Arizona
  6. #6 Re: Aem wideband completely innaccurate
    Jan 1970
    Maquoketa, Iowa
    It's easier to adjust/check with the key turned forward and car off. May have to run it a bit before you do that so it's not just reading air or play with it.
  7. #7 Re: Aem wideband completely innaccurate
    May 2008
    Schuyler, NE
    I honestly don't think I've ever found a formula online that has actually worked for me. I've had to figure them out for myself.
  8. #8 Re: Aem wideband completely innaccurate
    Oct 2012
    New Jersey
    None seem to work for me either. How did you figure them out?
    My afr gague is anywhere from 11-16 when I chop the throttle... HPT moves between 15.2 - 15.5
    I give up
  9. #9 Re: Aem wideband completely innaccurate
    May 2008
    Schuyler, NE
    Quote Originally Posted by JerzNick View Post
    I give up
    You have to do some math and figure out your voltage offset.
    For instance, my LM-1 had a 0-4v output, but HPT reads 0-5v. I had to adjust it for that.
  10. #10 Re: Aem wideband completely innaccurate
    Arizona
    You should always try to find your voltage offset and then figure that into your formula
  11. #11 Re: Aem wideband completely innaccurate
    Jan 2009
    Tallahassee, FL
    I found a PID to start on and had to mess with the voltage a little for it to be perfect.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: Aem wideband completely innaccurate
    I have absolutely no idea what most of this means lol but I'm going to hook my wb up to my dhp whenever I get my motor swapped. Do I have to jump through the same hoops?
  13. #13 Re: Aem wideband completely innaccurate
    Oct 2012
    New Jersey
    Wow. I am a moron. I hooked up to the wrong wire on my wb sensor.
    Now working perfectly with the +9.4 parameter.
  14. #14 Re: Aem wideband completely innaccurate
    Arizona
    Just command. Voltage in your wideband software with key in acc engine off say u command 2.5 volts then open up hptuners software and see what you read
  15. #15 Re: Aem wideband completely innaccurate
    Oct 2012
    New Jersey
    Noob question here. How do you command that?
  16. #16 Re: Aem wideband completely innaccurate
    Jan 2009
    Tallahassee, FL
    You can't program the AEM.
    77 Morris Garage B
  17. #17 Re: Aem wideband completely innaccurate
    Arizona
    You can't program the wideband voltage slope with arm? Wow well you could always use a volt meter and compare the readout to your HP tuners reading to get the same result
  1. wideband 02
    By 05grndprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2011, 05:53 AM
  2. Wideband
    By Wrongwayislost77 in forum PCM Tuning
    Last Post: 02-28-2011, 12:51 PM
  3. Wideband
    By TurboGTP in forum Turbo
    Last Post: 12-17-2009, 11:36 PM
  4. wideband o2 kit
    By popeyenate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-13-2009, 12:44 PM
