Thread: How importat the VE tune?
Results 1 to 17 of 17
  1. #1 How importat the VE tune?
    Aug 2008
    SOUTH TEXAS
    Reason i'm asking, is because i have not done it yet.
    I was told it wasn't really necessary.
    That all it does it maintains the car running when MAF sensor goes bad.
    How would not doing a VE tune affect my current tune?
    I have already covered or done MAF,02'S and timing tuning.
    What else is there to tune?
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  2. #2 Re: How importat the VE tune?
    the better your VE tune, the better your trims are from the beginning. i barely had to change my MAF table after the VE tune.
  3. #3 Re: How importat the VE tune?
    Aug 2008
    SOUTH TEXAS
    Maf tune was already adressed.
    So no worries.
    Thanx!
  4. #4 Re: How importat the VE tune?
    TDCRacing
    Guest
    I have never done it yet but may give it a try one day.
  5. #5 Re: How importat the VE tune?
    Jul 2008
    Germantown, Maryland
    I started with the VE tune just because I want to learn all I can, however as Josh was telling me the argument can go either way on whether you need the VE tune or not. I feel that it is kind of a safe mode if my MAF does go bad so I'd prefer to tune it.
  6. #6 Re: How importat the VE tune?
    Barksdale AFB, LA
    Agreed. If my MAF failed I don't want the PCM to rely on the factory VE tables to drive "blind". I'd rather it have a good picture of how the car breathes in its current state. Hence the VE tune.
    I also found tuning goes better with a good VE base. I think it is used for more than we know.
    2009 Subaru Impreza WRX STI
  7. #7 Re: How importat the VE tune?
    anyone got it good enough to where the car dies a bunch of times?
  8. #8 Re: How importat the VE tune?
    Barksdale AFB, LA
  9. #9 Re: How importat the VE tune?
    Bastard Reptile's Avatar
    Kansas City, MO
    Heh....me actually.
    I've done it twice, but the weather changes so much between the times I actually get to drive it that it basically does me no good. I'm always fiddling with the engine anyway.
  10. #10 Re: How importat the VE tune?
    Donating Users DOHCZ34's Avatar
    Traveling
    A lot of pcm code doesn't even reference the VE if the MAF is unplugged. The only year I know that is pretty much guarenteed to work is 00 code. I guess I'm pretty biased to 00 code since it's pretty universal, without the BS found in other year code..
    -Chris
  11. #11 Re: How importat the VE tune?
    i dunno. my friend who was doing the tuning said if you get it really dialed in the car starts dying while youre tuning it.
  12. #12 Re: How importat the VE tune?
    Kansas City, MO
    I think that's backwards. The point of a VE tune is to make it run better without the sensors in a worse case scenario.
    When you first start, it runs like poo....but as you progress, it idles and runs better.
  13. #13 Re: How importat the VE tune?
    Traveling
    I would fire a bullet into your friend and find someone else to do your tuning.
  14. #14 Re: How importat the VE tune?
    Barksdale AFB, LA
    My trims without the MAF plugged in are between 0 and -2. VE tune is spot on, and it doesn't die.
  15. #15 Re: How importat the VE tune?
    Jul 2008
    my car didn't idle all that bad but it's basically stock... I'm sure if I did some more work to it it would go crazy
  16. #16 Re: How importat the VE tune?
    we havent finished the tuning yet. it idles and cruises better already. we only did about an hour of VE and MAF tuning together.
  17. #17 Re: How importat the VE tune?
    Banned
    oswego
    no ve tune. Don't need one, if your maf fails why would you keep driving it? Who cares how your car runs when the maf fails lol, get a new maf. I wouldn't keep driving on my spare tire when one of my good ones went bad, would you? Stop wasting you time with ve tunes. I've been told by the best that they are useless. Tune the maf accordingly, it's really not hard. I tuned a gtp over emails all he did was gave me his average fuel trims, i gave him a number and bam (life the chef) his car is dialed in. Now i can tune wot stuff since his cruising trims are damn near perfect, actually better than my own car
    If you are having that much trouble dialing in fuel trims then there is something else going on, maybe a vac leak, who knows? I've always gotten it on 3-4 tries (depending on severity) on everyone else's cars and i'm not a genius or anything (well i am a legend in my own mind ) it's just taking what you've been taught, then changing it to make it easier. they say take 1/2 of the average, adjust the maf accordingly. I take 65% and that works so much better for me, gets so close on the first try.
  1. XP cam tune ?
    By GTP4 in forum PCM Tuning
    Last Post: 10-24-2008, 08:38 AM
  2. Need a tune up!!!
    By 52 picup in forum General Tech Discussion
    Last Post: 10-19-2008, 12:26 PM
  3. Anyone want to tune near MD?
    By Quicklynx in forum PCM Tuning
    Last Post: 10-13-2008, 10:00 AM
  4. Tune Up
    By bcrosby51 in forum General Tech Discussion
    Last Post: 08-20-2008, 03:19 PM
  5. Getting a tune done.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-15-2008, 01:50 PM
