You will be okay with the 02 in there, It will just toss the Po420 code. If you have that code set to Non report SES enabled Checked, Then it would even pass a obd2 Emission check.
So if i do what you guys just suggested the car will only run the diagnostic once and should stop then my engine should remain running normal. The computer will just think it has a bad CAT and it wont effect the way the engine runs? Oh and also i don't have the software i am just doing a **** load of research to find a solution to this issue. Will the above SES code try to run more than once? So that me and everyone else will know what to do![]()
Assuming you are going to leave the rear O2 installed and the codes for it enabled (as they are stock); if you set the Cat Diagnostic DTC(s) to "No MIL", the test will run 1 time, set the Cat DTC, and then future tests will not run.
If you disable the Cat diagnostic codes completely, the PCM may attempt to run and re-run the tests, but I would THINK it should immediately discontinue each test as soon as it sees that rear O2 sensor go rich. I do NOT know if it will keep trying to run the test of if it will discontinue running tests for that key cycle because I never had the chance to try it.
In tinytuner, go to diagnostics> cat diagnostics? and there are 2 tests to set to disable, I'm not at the program right now for specifics but I know they will disable the tests.
Other than that if you leave the rear 02 plugged in and in the exhaust, you can make a 2" or so spacer so the sensor is out of the exhaust stream and then it won't throw a code like it would with no cat there and in the exhaust stream.
