Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Results 1 to 20 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Jan 1970
    Maquoketa, Iowa
    In tinytuner, go to diagnostics> cat diagnostics? and there are 2 tests to set to disable, I'm not at the program right now for specifics but I know they will disable the tests.
    Other than that if you leave the rear 02 plugged in and in the exhaust, you can make a 2" or so spacer so the sensor is out of the exhaust stream and then it won't throw a code like it would with no cat there and in the exhaust stream.
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    SE Level Member Sinister Performance's Avatar
    Fort Wayne, IN
    Quote Originally Posted by FoSHO99 View Post
    What version of TinyTuner are you using? I have v3 and it isn't showing any cat diagnostics to disable at all...
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
