Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 181 to 200 of 253
  1. #1 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Feb 2009
    flintnasty MI
    it will cycle the fuel dump test a few times per drive cycle. Roughly 3 times for an 01 during cruising.
    One trick I have noticed works pretty good is to enable full time open loop, and you can even start lean cruising while removing the headache that is the rear o2 dump.
  2. #2 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Jun 2013
    Hollywood ,FL
    I have no clue what the hell I just read im new to the grand prix game got the 0420 code after putting an aftermarket header I cleared it with my obd2 scanner am I fine now or do I need the spark plug fouler other mod I have is intake no aftermarket pcm
  3. #3 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Smh
    Do the spark plug fouler trick like I suggested. It's $7 for god sake! Or until you can have the code deleted from the PCM your going to throw that code that's what I suggested several times to do the trick.
    04 Comp G.
  4. #4 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Smh
    I'm going to post this here as well
    04 Comp G.
  5. #5 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Even if you delete the code in the 01+ it'll dump fuel until it has a rear O2 not a simulator.
  6. #6 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    I stand corrected
    04 Comp G.
  7. #7 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    GT Level Member KoldAsIce's Avatar
    Mar 2013
    Staten Island, NY
    I know this post is majorly old BUT I was wondering if anyone has figured out exactly how to fix this either TT or DHP etc I just want a sure method to fix it! Thanks
    ZZP 10.3mm Wires, Autolite 605s, CAI, HP Tuners PCM,
    3" Catted DP, Straight Piped, 20% Tint, 5k HIDs, 6k Fogs
    220a (eBay) Alt , RF Prime Amp 1333w (RMS), Kicker 12" L7 750w (RMS), RF PBR Amp 75w (RMS x4)
    Alpine Type R (Front 5.25" 90w (RMS Each), Rear 6"x9" 100w (RMS Each)
  8. #8 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kemmerer, Wyoming
    the fix is to run a converter and a rear o2 sensor
  9. #9 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Mar 2013
    Staten Island, NY
    I have a o2 but had to remove my cat cause it was bad but thanks for telling me your solution
    Sent from my SGH-M919N using Tapatalk
  10. #10 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    you can get a high flow cat for like 50 off ebay, then use one of then simulator deals to pull the o2 out of the pipe to trick it.
  11. #11 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Mar 2013
    Staten Island, NY
    I know I can get a cat that's not the issue I'm just curious for the guys that don't have one and aren't gonna get one what they did to fix it.. everyone's solution couldn't have been to get a cat so I'm just curious I don't think I have the problem but like I said I'm curious to know
  12. #12 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Bastard Reptile's Avatar
    Kansas City, MO
    You don't have to run the converter, just leave the rear O2 in and turn off the catalyst codes.
  13. #13 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Mar 2013
    Staten Island, NY
    I got that BUT for a certain few 01+ it runs diagnostics mode regardless of the codes being tuned out.. I don't think I have the problem BUT after I had to remove the cat my rear o2 isn't working anymore .4 to .5 and that's it.. I know the last time my rear o2 didn't work and I fixed it my mpg went up quite a bit so I'm just curious.. maybe a o2 sim might work but I have a good o2 in there right now
  14. #14 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Mar 2013
    Staten Island, NY
    BTW I'm getting a p0140 code
  15. #15 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kansas City, MO
    You're right, they will still run the diagnostic. The trick is keeping the light off for the p0420 code, but keeping the sensor active so that it detects the catalyst diagnostic. Once the rear O2 picks it up, it stops. The sensor is either bad, or the circuit is damaged. The P0140 is telling you that one of those two things are happening.
  16. #16 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Mar 2013
    Staten Island, NY
    The o2 worked fine until I took the cat out but I will figure it out I guess
  17. #17 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kemmerer, Wyoming
    I wasn't 100% sure the converter was necessary, but I thought it was so the rear o2 sensor could see a difference from the front o2 sensor.
  18. #18 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kansas City, MO
    The only thing that the rear O2 is supposed to do, is detect when the converter is functioning properly or not, and in the case of some 01+ programming, a cat diagnostics code. It has no affect on how the front sensor functions. They are stand alone circuits. Turning a code to not reporting doesn't eliminate the fact that the sensor should still function, just not report a diagnostic problem.
  19. #19 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kemmerer, Wyoming
    this isn't the first time I misunderstood how something worked
  20. #20 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    You can "fix" this issue with tinytuner
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
