Thread: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
Page 13 of 13 FirstFirst ... 3111213
Results 241 to 253 of 253
  1. #241 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    if you have a older vs of hp it will read and flash a bin file. the new vs will not.
  2. #242 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    So, since someone bumped it. Anyone notice even with the diag tests disabled in TT that sometimes it'll still want to run the tests briefly? Unless it something else, can still randomly rise -10 to -20 ltfts gradually for like a minute then it drops back to normal. Literally only does it after I fill up, the car is warmed up, turn it off, fill it up, drive off, mile or 2 later ltfts rise then drop back to normal a couple miles more down the road.
    2012 F150 STX
    - Gonna be a race truck
  3. #243 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    that sounds like the evap it can mess with your ltft's. i deleted mine, it dont do that crap no more.
  4. #244 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    So it may have been discussed in this thread, but I cannot seem to find it. Will the O2-emulator (such as the one sold by ZZP) eliminate the cat-diagnostic check?? ZZP has free shipping today, and I may take advantage of that.
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  5. #245 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kemmerer, Wyoming
    Sometimes it does, not always
  6. #246 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by SgtMarshal View Post
    Any idea why it would work for some but not others?? Seems like it would be an all or nothing deal, unless something else was screwed up in the PCM or secondary O2 sensor wiring??
    2002 GTP sedan:
  7. #247 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kemmerer, Wyoming
    Trannyman, aka Dave at TEP says the o2 sim won't fix the catalytic converter diagnostic
  8. #248 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Apr 2012
    Dayton, OH
    Quote Originally Posted by 97AutoXVette View Post
    Don't think so. How I think it works is the test runs the car rich then it looks for the rear 02 sensor to see that then it stops the test. If there isn't an 02 sensor then it can't stop the test until it times out after so long.
    Sent from my SM-S902L using Tapatalk
    2012 F150 STX
  9. #249 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Jan 2017
    xx
    Slightly resurrecting a dead thread (but hey it's a sticky):
    The temp for CAT Diagnostic Enable Coolant Temp should really be like 285 instead of -285. The diagnostic will run anyway if it's set to -285 because it will always be above that temperature. It would happen once every drive cycle for me until interrupted by hitting the gas hard or something (the wideband would go way rich, like .68 lambda). After it was interrupted, it wouldn't run again, but it was still annoying. Setting it to a high positive number has kept it from coming back.
  10. #250 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Oct 2017
    Dover TN
    I read the entire thing tonight. Do us newbies get any achievement awards? There was usefull information and as always there was a little drama in there but at least it was kept pretty civil. I'm so new to tuning I don't even have a way to hook my Commodore 64 up to my OBDII yet. Anyway, I'm looking for a paper (yes a book, with a cover, bindings and PAPER) back or hardcover book you suggest to read on tuning. I'm so new I had to look up ltft and stft. Hoping to get to know and learn from each of you guys.
  11. #251 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    GTP Level Member
    Jun 2016
    Cleveland ohio
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  12. #252 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    Kemmerer, Wyoming
  13. #253 Re: Removing rear O2 sensor on 01-newer PCMs -- Things you should know
    GTP Level Member
    Jun 2016
    Cleveland ohio
    ^ That's the book I have. Very good information. The best information for our specific platform is in this pcm tuning forum. Lots to read and absorb!! I'm not sure what you are planning to tune with but the Commodore 64 won't cut it! LOL
  1. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  2. Considering a 05 or newer GP
    By kimbo in forum Off Topic Discussion
    Last Post: 09-21-2008, 09:05 PM
  3. a question about these PCMs...
    By agent505 in forum PCM Tuning
    Last Post: 06-02-2008, 07:24 PM
  4. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
