Thread: Timing table
Results 1 to 20 of 28
  1. #1 Timing table
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    I'm just starting to tune up my car. I have a cam and headers soon to come. My car is N/A. What year and type would have the best timing table to copy over as a starting point.
    Thanks
    97 Bonneville SE Not so much a 97 anymore
  2. #2 Re: Timing table
    My best bet would be an '04+ table as IIRC they are more aggressive on the timing curve.
    Then go from there.
    I was on a stock valvetrain'd L36, AFR sitting around 12.0~, 36*~ timing at WOT.
    Ran 87 octane with stock exhaust without the u-bend. No knock, evah.
  3. #3 Re: Timing table
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by blueguy91 View Post
    Actually, the AFR was commanded at 13.0.
  4. #4 Re: Timing table
    Quote Originally Posted by Reptile View Post
    Thats much better.
  5. #5 Re: Timing table
    rumour has is: 27* is MBT.
    Meaning going over that is pointless.
    Apparently run less octane if you can run 27* at WOT without KR.
    12.0 is still too rich, run 12.5-13.0.
  6. #6 Re: Timing table
    Kansas City, MO
    Still ran good for a GT.
  7. #7 Re: Timing table
    Pooped on Cody's blower car until 75~
  8. #8 Re: Timing table
    Topeka, KS
    It's amazing what timing and a good tune can do
    Ohio
    Mine is 12.5 at wot, 30° on 93.
  10. #10 Re: Timing table
    So did anyone read what I typed?
    Did anyone dyno their cars at different amounts of timing and see where it stopped making power?
    Ohio
    Nobody cares matt .. MOAR TIMING!
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    I seem to recall that gains from timing were lost at anything over 24*.... Thats boosted though.
    Sent from my Droid
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  13. #13 Re: Timing table
    I seem to recall many saying over 18 on pump gas is asking for it.
    Including vendors.
    I also seem to recall a particular overkill stating 27* if N/A being as far as you go, then you drop octane.
  14. #14 Re: Timing table
    Justin.. 05 timing table.
    Maf tune it
    VE it for the flow mods.
    Then hop on the timing.
  15. #15 Re: Timing table
    Just set it at 27* from the get go.
    Mine didn't knock.
    Ever.
    But god forbid you touch timing on blower cars.
  16. #16 Re: Timing table
    My car would only run 21-22* timing with headers and 94 octane while N/A.
    It was a whore, still is.
  17. #17 Re: Timing table
    Like I said, I ran 87.
    I think it's that Canadian air.
  18. #18 Re: Timing table
    Mine currently would like 93. I'm about to go in for VE though. Pretty sure it's way off based on my gearing, etc etc etc.
  19. #19 Re: Timing table
    Nov 2009
    Central Jersey
    sweet I can't wait to get the XP laptop from work to use DHP. I know for a fact I'm running crazy rich too.
    Thanks guys
  20. #20 Re: Timing table
    Sometimes DHP plays nice with Win 7
  1. Anyone have a Maf Table for LQ4?
    By rynoman03 in forum PCM Tuning
    Last Post: 06-07-2012, 12:02 AM
  2. Replies: 5
    Last Post: 05-18-2011, 04:20 PM
  3. Actual Timing > Spark Table
    By JoshMcMadMac in forum PCM Tuning
    Last Post: 10-09-2009, 06:49 AM
  4. Can't get timing to match table values!??!
    By DanGTP in forum PCM Tuning
    Last Post: 10-25-2008, 11:45 PM
  5. Eddie's table modifier, my table too big?
    By Sabrewings in forum PCM Tuning
    Last Post: 06-06-2008, 09:00 PM
