Thread: Tapping a TPS and RPM signal
Results 1 to 3 of 3
  1. #1 Tapping a TPS and RPM signal
    Sep 2012
    Watkins Glen, NY
    Not certain this is right section so please move if its not mods.
    I have my car info in the introduction section but to sum up, its a 94 cavalier, a 3800sc out of a '00 buick, a 94 olds 88 pcm, and some combination of them in the wiring harness. Either way, the cars currently obd1 which makes tuning more complicated. I bought Zeitronix ZT-2 for data logging and trying to wire it in right now. I tapped into the white wire on the ICM (E -Pin) which I found in an online schematic. Unfortunately I am not getting any voltage from that wire. So now I'm stuck as to where else i would tap into and get a quality signal?
    Next is the throttle reading. Where would i tap into for that? Right off the sensor? Which wire?
    Hoping to get the logs needed tomorrow so i can have my pcm tuned and stay out of the lean issues I'm having right now.
    Any help is greatly appreciated
    Dale
  2. #2 Re: Tapping a TPS and RPM signal
    HUDSON
    WHen I had "OBD1" vehicals, I used WIN-ALDL for data logging, it workerd great, and is free. All instructions, from building the OBD-1 cable, to using the program can be found on the net.
  3. #3 Re: Tapping a TPS and RPM signal
    Sep 2012
    Watkins Glen, NY
    I bought a moates cable but it appears when they did this swap they never hooked up that port.. So im stuck with zeitronix. Just need rpm to work so I can get this puppy tuned.
  1. 06 GP Base signal conversion to Fog/signal
    By kmkecho in forum General Tech Discussion
    Last Post: 08-19-2012, 11:51 PM
  2. tapping in engine
    By almighty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-21-2010, 11:13 PM
  3. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
  4. HELP: tapping noise!
    By fst in forum General Tech Discussion
    Last Post: 08-28-2008, 10:46 PM
