Thread: Help with PCM
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Help with PCM
    Chicago, IL
    OK here's what I see. If I am facing my car from the front, on the right side there is a sensor attached to the k&n air intake. Under that still on the right is three more "sensors" attached to a silver plate. Am I even in the right area?
  2. #22 Re: Help with PCM
    Banned
    Wichita Falls, Texas
    See the dark blue thing underneath the red arrow? Thats your PCM, it won't be blue, it will be a ugly metallic color, bunch of wires going to it.
  3. #23 Re: Help with PCM
    Banned
  4. #24 Re: Help with PCM
    Chicago, IL
    I see this:
    and I see this:
    If its not those I must be missing something
  5. #25 Re: Help with PCM
    Banned
    What do you drive?
  6. #26 Re: Help with PCM
    Barksdale AFB, LA
    Quote Originally Posted by Street Wolf View Post
    What do you drive?
    Judging by his screen name, an 04. Which also makes sense given the pics he posted.
    2009 Subaru Impreza WRX STI
  7. #27 Re: Help with PCM
    TDCRacing
    Guest
    No that is your drive by wire and your maf electrical wires. Just look under or by where street worf put the red arrow.
  8. #28 Re: Help with PCM
    Chicago, IL
    What do you drive?
    I have an 04 Grand Prix
  9. #29 Re: Help with PCM
    Barksdale AFB, LA
    Quote Originally Posted by TDCRacing View Post
    No, the first picture he posted is his PCM. The second picture is the MAF, I believe.
  10. #30 Re: Help with PCM
    TDCRacing
    Guest
    Quote Originally Posted by Sabrewings View Post
    I'm sorry now that i look at it you are right. There is a box with heat sinks on it that looked siilar to that pic that is located on the tb
  11. #31 Re: Help with PCM
    Chicago, IL
    So all three of those in the first picture is my PCM?
  12. #32 Re: Help with PCM
    SE Level Member Stonewall's Avatar
    Rochester, NY
    Yea actually those 3 things you are calling sensors are electrical connectors and they connect to the PCM. You lift the gray lever on the connectors and each one will unplug from the PCM. Then you'll have to remove the bolts that hold the PCM down. I think the K&N kit has a tray for the PCM, so you'll have to remove the tray along with the PCM here are some pics.
    06 GT, HPtuner, PLX Wideband, AFC2.0, K&N CAI, PEM/PLOG 3"DP, ZZP 3.5MPS, CORSA CATBACK, GMPP STB's, GMPP HD Tarms
  13. #33 Re: Help with PCM
    Jan 2009
    Ottawa, Ontario, Canada
    Is it possible to have a PCM that can be connected to a laptop with software, so that I can do custom tuning without having to ship it off for reprogramming?
  14. #34 Re: Help with PCM
    TDCRacing
    Guest
pcm
