Thread: Am I an idiot?
Results 1 to 20 of 22
95concours Am I an idiot? 03-28-2012, 09:02 AM
Fivefingerdeathpunch Re: Am I an idiot? 03-28-2012, 09:07 AM
matt5112 Shouldn't affect it . 03-28-2012, 09:10 AM
95concours Re: Am I an idiot? 03-28-2012, 09:21 AM
95concours Re: Am I an idiot? 03-28-2012, 09:22 AM
matt5112 Put stock pcm back in. 03-28-2012, 09:26 AM
MoarkatsINmuhtrailer Agreed 03-28-2012, 09:28 AM
MoarkatsINmuhtrailer Is this a top swapped car?... 03-28-2012, 09:29 AM
95concours Re: Am I an idiot? 03-28-2012, 09:32 AM
MoarkatsINmuhtrailer Ohh ic. 03-28-2012, 09:32 AM
95concours Re: Am I an idiot? 03-28-2012, 09:34 AM
95concours Re: Am I an idiot? 03-28-2012, 09:35 AM
95concours Re: Am I an idiot? 03-28-2012, 09:51 AM
GTPSHAWTY Re: Am I an idiot? 03-28-2012, 12:21 PM
MoarkatsINmuhtrailer Re: Am I an idiot? 03-28-2012, 12:27 PM
95concours Re: Am I an idiot? 03-28-2012, 01:18 PM
95concours Re: Am I an idiot? 03-28-2012, 01:16 PM
OH4CompG Re: Am I an idiot? 03-28-2012, 02:43 PM
95concours Re: Am I an idiot? 03-28-2012, 02:45 PM
Swiggles Sounds to me like your tstat... 03-29-2012, 04:57 PM
95concours Re: Am I an idiot? 03-29-2012, 04:59 PM
dsmuts Re: Am I an idiot? 03-29-2012, 05:06 PM
  1. #1 Am I an idiot?
    SE Level Member 95concours's Avatar
    Mar 2012
    Bath ontario
    So, in order to get my gp to go through an E-test I had to use a stock pcm. I installed the new one went to do the e-test and immediately went back to the old one with a tune. Is it possible that I may have screwed up the custom tune from switching back and fourth? The car is great until just under half pedal than misfires like crazy afterward.
    I was in such desperation to get the car to pass that I may have thoughtlessly done something quite wrong.
    So, Am I a complete idiot?
  2. #2 Re: Am I an idiot?
    So it misfires with both PCM's??????
    Maybe you have a bad coil or plugs and wires. I think its time you figure this out with some testing.
    Mods?
    And what kind of tune?
  4. #4 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    No, It's only the one pcm doing it. I bought the car with the tune and he did it himself so I have no clue what has been done as far as that is concerned. The mods as far as I know is
    Spectre cone filter
    thrasher intake box
    ported exhaust manifold
    3 inch exhaust all the way back
    exhaust has been heat wrapped in engine bay
    magnaflow high flow cat
    magnaflow mufflers (not sure what type)
    U bend delete
    180 t-stat
    colder plugs
    Taylor spiro pro 8mm wires
    And thats all it has for engine mods anyway
  5. #5 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    and has the stock pulley
    Ohio
    Agreed
    Ohio
    Is this a top swapped car? Cuz your profile says a 97 GT
  9. #9 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    No, It's a gt with a 98 gtp motor and trans.
    Ohio
    Ohh ic.
  11. #11 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    I guess I am gonna have to put the stock one back till I get one with a good tune.
  12. #12 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    I want to cry lol.
  13. #13 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    Ahhh, i just went out to take a peek at the car and noticed that there was no heat on the rad cap so I checked if there was pressure in the upper rad hose and there was none. so I opened the cap an the rad fluid was ice cold. I just came back from a fairly long drive. So Im wondering if maybe the problem lies within that aspect and not the tune.
    But thats for a different thread on the riverbank.
  14. #14 Re: Am I an idiot?
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    clogged raid/?
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  15. #15 Re: Am I an idiot?
    Ohio
    possibly...
  16. #16 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    Changed the pcm back to stock and it definitely helped but the symptom is still there, just not as severe. but before I had problems the fans would run for about 20 seconds after shutting off the car, now it doesn't do that any more.
  17. #17 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    Now, its working lol.
  18. #18 Re: Am I an idiot?
    Portland Oregon
    You can program the fans to stay on at key off. Guessing that was done in the tuned pcm.
  19. #19 Re: Am I an idiot?
    Mar 2012
    Bath ontario
    Yea, that's what I figured, so if they aren't doing what they are supposed to I'm thinking that other things might be all loopy.
    Quincy, Mass
    Sounds to me like your tstat is bad. When they fail they fail at open so coolant is constantly going into your motor and not heating up. Mine did it one winter and I'd leave the car running for an hour with no change in temp.
    No more GP 04 Impala SS Indy:
  1. DOH! im an idiot. :)
    By BoostJunki3 in forum Off Topic Discussion
    Last Post: 10-27-2009, 06:36 PM
  2. I am an Idiot
    By kingbrentdwyer in forum Audio, Security & Visual Electronics
    Last Post: 12-16-2008, 06:27 PM
  3. GP Idiot
    By mzendano in forum Track Sessions and Kills
    Last Post: 12-03-2008, 04:26 PM
  4. Okay, aparently I'm and idiot. Gen V help
    By Street Wolf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2008, 03:34 PM
  5. I am an idiot
    By UR LOSN in forum Off Topic Discussion
    Last Post: 02-07-2008, 07:52 AM
