Thread: Okay, aparently I'm and idiot. Gen V help
Results 1 to 17 of 17
  1. #1 Okay, aparently I'm and idiot. Gen V help
    Banned
    Wichita Falls, Texas
    Okay, seeing as I must be an idiot becuase I can't figure out what the hell is wrong. I just installed a GenV a few weeks ago as most of you already know, and I had a problem with KR and found out that it was caused by a massive vacuum leak from a broken line that connected to the boost gauge.
    Well now I have another problem. My car runs horrible WOT in the lower RPM's right after it shifts gears, but once it gets back up into the higher RPM's again it takes off like a bat out of hell.
    Anyone have a guess at what might be the problem here?
    And if at all possible can I get someone to take quite a few pictures of their GenV setup on their 97-03 car? Just pictures of the hoses/connectors and such and where they are going. Just to double check and make sure I did'nt do something stupid and connect something wrong, or not at all.
  2. #2 Re: Okay, aparently I'm and idiot. Gen V help
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    Check the BBV operation.
    When the car is off is it all the way down at the 9:00 spot? When you start it does it go all the way up to the 12:00 position? When you hit the throttle cable on the TB does the BBV move smooth?
  3. #3 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Quote Originally Posted by VinnieGTP View Post
    I assumed so, but I'll certianly be checking that once it's daylight outside.
  4. #4 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Hey Vinnie, I'm going to post a video real quick to show you just what I'm talking about.
    My speedometer damn near stops after it changes gear, and take in mind this is with a 3.25 pulley on it which is much longer than what I should be able to run safely.
  5. #5 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Video, I feel embarrassed to even post this. lol -
    ****ty Run
  6. #6 Re: Okay, aparently I'm and idiot. Gen V help
    Moore, Oklahoma
    You sure it ain't a programming issue with the PCM file? I'd like to see the video too, but to me it doesn't sound mechanical, but I maybe wrong too.
    Question for Vinnie... Ok when my car is off the BBV is in the 9 o'clock position however I noticed the other day when idling the BBV was in the 10-11 o clock range, not at 12, does this matter? I didn't think much of it, I figured if it goes to 9 when its off, it should at WOT too. This thread questions my theory though, thoughts? Thanks!
    Shawn W. Larsen
  7. #7 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Quote Originally Posted by Iron Indian View Post
    Well it could be, but the only thing that makes me think thats not the problem is it ran great before the install. Not a single problem, not all of a sudden I have the vacuum leak fixed and I actually actually go WOT this new problem pops up out of the blue.
  8. #8 Re: Okay, aparently I'm and idiot. Gen V help
    Moore, Oklahoma
    True, then again changing out the S/C is a big mod, I mean you moving more air so things may need to be adjusted. I donno, like I said I maybe wrong. But a retune could be in order. Check out the obvious under the hood and if you find nothing, try a fresh bin file and start over again, see what happens.
    Shawn W. Larsen
  9. #9 Re: Okay, aparently I'm and idiot. Gen V help
    TDCRacing
    Guest
    What is that flashing? Is that the SES light? Have you checked into that?
  10. #10 Re: Okay, aparently I'm and idiot. Gen V help
    Las Cruces, NM
    Video looks like you're just recovering from bad wheel spin and thats why the speedo is hesitating like that.
    If it doesn't do to the 12:00 position at idle theres an issue. Does it close again when you blip the throttle? Can you gently manualy move it to the 9:00 position with the car off?
  11. #11 Re: Okay, aparently I'm and idiot. Gen V help
    Bastard Reptile's Avatar
    Kansas City, MO
    That sounds like Pulled timing to me....As in, 0* timing, then all of a sudden after about 3 seconds it runs like a raped ape.
  12. #12 Re: Okay, aparently I'm and idiot. Gen V help
    Jul 2008
    sumter,south carolina
    Quote Originally Posted by Street Wolf View Post
    ****ty Run
    why are all of your dummy lights on... on dash
  13. #13 Re: Okay, aparently I'm and idiot. Gen V help
    TDCRacing
    Guest
    Quote Originally Posted by TDCRacing View Post
  14. #14 Re: Okay, aparently I'm and idiot. Gen V help
    Moore, Oklahoma
    Figured out anything yet Street Wolf? Curious to what it was...
    Shawn W. Larsen
  15. #15 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Sorry guys, did'nt do anything with it yesterday.
    Going to go workout, ride the bike, check on some parts for a member, then see what I can figure out.
  16. #16 Re: Okay, aparently I'm and idiot. Gen V help
    Banned
    Well I checked once I pulled in just a few moments ago. At idle it is in the 12 O'Clock position, and when I blip the throttle it moves. I did'nt rev it up all the way or anything though, but it seems to be working correctly.
    Multiple reasons why those are all blinking, nothing to do with the current problem though.
    And that is the Security light blinking, not the SES light.
  17. #17 Re: Okay, aparently I'm and idiot. Gen V help
    SE Level Member Keet04GTP's Avatar
    Jul 2008
    Tulsa
    Have you pulled your plugs to see if you have popped a piston? I ran a smaller pulley than I should have once... I kept popping chunks off the top of the piston and the debris would smash the plug to where it would only run good at higher RPM's... If you did... it would most likely be piston 4 or 6... Those are the ones I always had problems with... Just a thought...
    2004 White GTP...Stock Stock Stock...Soon...3.0 ZZP MPS, ported blower, Pacesetter Coated Headers, FWI, Tuned PCM, VS cam, 105# springs, JP timing chain, whisper resonator and custom exhaust...My next goal(after I rebuild my savings)... 2.5" IC, 2.6 pulley, XPZ Cam, S3 heads, and a tranny....
  1. I am an idiot
    By UR LOSN in forum Off Topic Discussion
    Last Post: 02-07-2008, 07:52 AM
