Thread: Do i need a tune for just headers?
Results 1 to 20 of 32
  1. #1 Do i need a tune for just headers?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    I have a stock 97 gtp the only mod i have is a HAI and it makes my ses light come and flash. I planned on doing a 3.4 pulley setup but for right now i just want headers. I was wondering if i should buy a zzp tuned pcm or just tune mine my self (If so what kind of tuner is best). Also do i even need a tune for headers? thanks for looking.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: Do i need a tune for just headers?
    Intake shouldn't make your ses light flash if it's flashing you have a misfire. I ran on the stock tune with my 3.4 setup for a while before i threw my zzp pcm into it. But fix your misfire first.
  3. #3 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    but there's nothing wrong with my car ive cleared the code several times and it keeps popping up. did you have this problem before
  4. #4 Re: Do i need a tune for just headers?
    what code pops up? If it's flashing that almost always means there is a misfire.
  5. #5 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    i dont know the exact code but at my dads shop it reads as a misfire
  6. #6 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    sorry random misfire i also have ngk plugs in it if that changes anything
  7. #7 Re: Do i need a tune for just headers?
    P0300. Are they platinum plugs? I'd swap them out for some autolite 606's and see if it makes any difference.
  8. #8 Re: Do i need a tune for just headers?
    change the plug wires too.
  9. #9 Re: Do i need a tune for just headers?
    Pennsylvania
    Headers are fine on stock tune.
  10. #10 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    wires have been done the car went 155k miles with original plugs and wires and struts and other things
    the plugs are tr551x
    heres the specs
    Iridium IX Plug, 14mm Thread Size, 17.55mm (.691")Reach, 5/8" (16mm)Hex Size, TaperedSeat, Resistor, SolidTerminal Nut, Projected Tip, Fine Wire (0.6mm) IridiumCenter Electrode,Tapered CutGround Electrode, .060" (1.52mm) Gap, Heat Range 5
  11. #11 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    Quote Originally Posted by SlowNA06 View Post
    thank you
  12. #12 Re: Do i need a tune for just headers?
    when you get a random misfire, that means its jumping around, not 1 steady cylinder.
    change the plugs if no change, change the wires.
    what wires did you get when you changed them?
  13. #13 Re: Do i need a tune for just headers?
    Texas
    A tune isn't necessarily needed, but to get the most hp from the headers it's recommended.
    85 Corvette
    01 TA
    03 Z06
  14. #14 Re: Do i need a tune for just headers?
    The Boss Iceman6669's Avatar
    Jun 2011
    Flashing SES light means Multi Misses.. I would start with the coils... Or the ICM..... But I would get it fixed.... Not too good.. REALLY would not do a pulley drop on that stuff... I know thats not your question. Just trying to help.
    2011 F-150 Yote powered
  15. #15 Re: Do i need a tune for just headers?
    utah
    your car is not fine. if you keep clearing the code and it comes back your car is screaming "im broke dont kill me" i would do plugs, wires, coils, icm, in that order. with some check for vac leaks thrown in for good measure
  16. #16 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    im gonna do the plugs. the wires are acdelco plug wires. i havent checked the icm or the coils and they are both original on the car.
  17. #17 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    what plugs are reccomended for headers and such?
  18. #18 Re: Do i need a tune for just headers?
    Yay, link in signature.
  19. #19 Re: Do i need a tune for just headers?
    Jun 2011
    thank you.. I was looking for the link to link tha guy...
  20. #20 Re: Do i need a tune for just headers?
    Sep 2011
    palm harbor florida
    the plugs i have arent even 10k old and they arent platnium either.
  1. Headers and Tune = MPG?
    By RCND in forum General Tech Discussion
    Last Post: 05-04-2011, 11:22 PM
  2. SD headers/plugs/t-stat/3.4/tune install w/pics
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 10-30-2010, 10:29 AM
  3. before/after headers W/w.o. tune.
    By quadracer960 in forum General Tech Discussion
    Last Post: 10-10-2010, 03:51 PM
  4. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  5. Re-Tune after 1.9's and headers
    By xringshooter7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-10-2009, 05:32 PM
