Thread: Question for you tuner guys
Results 1 to 13 of 13
  1. #1 Question for you tuner guys
    Houston
    For some reason, my car used to pass inspection. As of a few years ago, I was told that the car could not be inspected because I can only have one monitor show "not ready", and I have two showing not ready. Catalyst and EGR. The EGR is gonzo, so it will never show ready, and the codes are apparently tuned to show as pending...so thats all good. After looking through some old paperwork, I noticed that since I bought the car, it has never shown the catalyst as ready but it passed. So they must have changed the inspection laws. Basically, is there anything while tuning the PCM that will disable the catalyst from completing its test?
  2. #2 Re: Question for you tuner guys
    Buffalo
    has the car had its battery disconnected or the faults cleared recently?
  3. #3 Re: Question for you tuner guys
    Houston
    Yes, the battery has died numerous times due to not driving it. But I've put over 1000 miles on it within about 3 months, without the battery dieing in between, and it still shows not ready.
  4. #4 Re: Question for you tuner guys
    is your CAT "high flow" by chance? are you running a tuned PCM or stock?
  5. #5 Re: Question for you tuner guys
    Houston
    Quote Originally Posted by gtpsleeper View Post
    I think it might be. It has a 3"downpipe and a 3" exhaust with cutout back to the Y. If that were the case, would a high flow cat not complete its test? (and yes, the pcm is tuned) These are some pics of underneath:
  6. #6 Re: Question for you tuner guys
    codes set to pending or no report? cause no report shows a fat check mark, right?
  7. #7 Re: Question for you tuner guys
    Houston
    They appear to be set to pending. Because I have 2 egr codes that dont trigger the CEL and when I connect my code scanner to it, it always shows them as pending. Those are the only codes that I have, there are no Cat codes.
  8. #8 Re: Question for you tuner guys
    if there are no cat codes then they must have been set to "non reporting" (someone correct me if im wrong please as I cant remember off hand for sure) and therefore would not run a check...
  9. #9 Re: Question for you tuner guys
    Houston
    Hmmm...Im thinking Im gonna have to take this to Tengis and have him look at the tune. Its just sooooo frustrating, cuz the car runs great.
  10. #10 Re: Question for you tuner guys
    Since you're only allowed one, you can enable cat codes OR try the WB EGR thing.
    GM cat was triangular in shape IIRC, so that might help in identification, but that doesnt matter. It only matters if it will pass the P0420.
    Since the EGR isn't there, if you want it to show "ready" you'll have to hook a wideband up and hook the WB output to the EGR position wire. Having done that, my PCM is convinced my EGR is still operational even with all of the codes disabled.
  11. #11 Re: Question for you tuner guys
    Houston
    Really?! So if you connect your code reader it shows the EGR ready?? If so, Im definitely jumping on that! Im so tired of dealing with this. I freaking love this car, and I dont really want to buy another car that I only drive one day a week.
    Quincy, Mass
    I set all my emissions codes to no reporting and all my tests were ready as soon as I loaded the tune. The egr enable temp also has to set to 284 or whatever the max is.
    No more GP 04 Impala SS Indy:
  13. #13 Re: Question for you tuner guys
    Houston
    Really....so you think I should purchase a tuner just for this, or just take it to Tengis and have him do it?
  1. Question for you guys
    By Slowburn in forum Off Topic Discussion
    Last Post: 10-11-2010, 02:59 PM
  2. tuner question
    By DaytonaGTP in forum General Tech Discussion
    Last Post: 04-11-2010, 10:30 PM
  3. HP Tuner question
    By mikesarebetter in forum PCM Tuning
    Last Post: 11-03-2009, 09:27 PM
  4. is there any PCM tuner guys in northern IL
    By GTPJOE90 in forum PCM Tuning
    Last Post: 09-17-2009, 12:25 AM
  5. hp tuner question
    By 2000GTP in forum PCM Tuning
    Last Post: 11-02-2008, 08:52 PM
