Thread: HP Tuner question
Results 1 to 3 of 3
  1. #1 HP Tuner question
    SE Level Member mikesarebetter's Avatar
    Spearfish, sd
    was curious if you need a wideband sensor to see af ratio or if the hp tuner does that in its running scan? don't have either one just tryin to figure out what all i'll need to tune it properly
    2003 GTP, pacesetter headers, colder plugs, zzp pcm for now, CAI, 3.5 pulley and 180tstat
  2. #2 Re: HP Tuner question
    Donating Users chrisb's Avatar
    Bucyrus, OH
    hptuners does show afr but without a wideband you cant get a accurate range from wot to stoichiometric ratio. Thats because the narrowband is only accurate around 14.68 AFR.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  3. #3 Re: HP Tuner question
    Charles City, IA
    You need a wide band. Then you have to wire it into the cars computer so hptuners can see the signal unless you get the pro version of hptuners.
    SMGPFC Two Nipple General
  1. PCM or a TUNER
    By MARKS99 in forum General Tech Discussion
    Last Post: 03-26-2009, 12:03 PM
  2. tuner near chi
    By gotboost3 in forum Midwest
    Last Post: 03-21-2009, 02:39 AM
  3. DHP Tuner
    By Clar2478 in forum PCM Tuning
    Last Post: 03-08-2009, 10:57 PM
  4. hp tuner question
    By 2000GTP in forum PCM Tuning
    Last Post: 11-02-2008, 08:52 PM
