Thread: questions on pcm for new l67
Results 1 to 11 of 11
  1. #1 questions on pcm for new l67
    Jan 2012
    Grand Rapids, MI
    Okay so I’m pretty new to the grand prix and 3800 world and the world of pcm tuning. I’ve got a 2000 gtp body but I’m putting a 99 supercharged 3800 in it this weekend. I’m putting headers, HAI, 180 thermostat, 104 autolightes, spark plugs wires, a 3.4 pulley, and a 3.29 built Trans. My question is can I use my old pcm, that was tuned for the 3.4 pulley and Trans before I got the car, and if I can use it how long will it last? Also should I just order one from overkill or is there someone in Grand Rapids anyone knows that’s good with this stuff or something else?
  2. #2 Re: questions on pcm for new l67
    You can use the old PCM, but with a trans that has a 3.29 ratio, you'll be banging off the rev limiter unless you change that in the trans settings.
  3. #3 Re: questions on pcm for new l67
    If it worked with the motor and trans you are using then you'll be fine.
  4. #4 Re: questions on pcm for new l67
    Jan 2012
    Grand Rapids, MI
    It was tuned for the transmission before but I were bouncing off the rev limiter all the time, is there any way to change the Trans setting without a complete tune. And it’s not tuned for the headers and HAI I don’t know if that makes a difference or not. Also the old motor blew up with the last computer and I think it had something to do with that or the crap tone of miles and no really flow mods.
  5. #5 Re: questions on pcm for new l67
    How did it blow? Chipped piston? rod knock? You'd be better off taking the car and getting it tuned.
  6. #6 Re: questions on pcm for new l67
    Go buy a DHP PCM.
    Tell 3800 Performance you want the GT trans settings in the PCM.
    Done.
    Also, if it was bouncing off the rev limiter, then it WASN'T correctly tuned.
  7. #7 Re: questions on pcm for new l67
    Jan 2012
    Grand Rapids, MI
    Yeah I don’t think it was correctly tuned and no compression in piston third and messed up the heads and stuff. And I was wondering if it makes any difference that it came out of a Buick regal?
  8. #8 Re: questions on pcm for new l67
    mileage wasn't a factor in that motor blowing up it was not enough flow mods. I have 210K on mine with no problems.
  9. #9 Re: questions on pcm for new l67
    Jan 2012
    Grand Rapids, MI
    Thats how much mine had! But Yeah your right, I just tell myself that to make me feel a little better lol
  10. #10 Re: questions on pcm for new l67
    I'm sure my motor will outlast my car. The body is getting rough.
  11. #11 Re: questions on pcm for new l67
    Feb 2009
    flintnasty MI
    There are probalby 10+ people in grand rapids that would tune your trans for a bag of tacos.
  1. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  2. new here with questions
    By wide open 97 in forum Visual/Body Modifications
    Last Post: 12-25-2010, 04:07 PM
  3. NIC cam questions
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 02:20 AM
  4. HV3 questions...
    By whitelightnin04MC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-23-2010, 11:43 PM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
