Thread: fiero 3800 swap
Results 1 to 5 of 5
Juanmiguel fiero 3800 swap 02-10-2012, 07:35 PM
darkhorizon Re: fiero 3800 swap 02-13-2012, 09:42 AM
Juanmiguel Re: fiero 3800 swap 02-13-2012, 10:20 AM
JoRoW99 Re: fiero 3800 swap 02-13-2012, 10:48 AM
darkhorizon Re: fiero 3800 swap 02-13-2012, 11:02 AM
  1. #1 fiero 3800 swap
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I've got a guy here that wants to swap a SCed 3800 out of a 2000 buick (regal I assume) into a fiero with manual transmission and no A/C. I was wondering what to do with it regarding tune/PCM. Leave the 2000 tune/pcm? I'm not sure if it will even turn on without the transmission plugged in.
  2. #2 Re: fiero 3800 swap
    Feb 2009
    flintnasty MI
    The pcm does not really care that there is no transmission connected. You will throw alot of DTC codes that should be removed, but this process is not really rocket science.
    The 01+ bin files will require the security bits disabled, which can be a bit tricky. I have always ran 98 pcm/code on my manual trans stuff as it seems to be the easiest.
  3. #3 Re: fiero 3800 swap
    Mexico
    Thanks man, that does give me a good starting point.
  4. #4 Re: fiero 3800 swap
    Grand Island, Nebraska
    You could try manual V6 camaro tranny tables, but i really dont know im just brainstorming.
  5. #5 Re: fiero 3800 swap
    Feb 2009
    flintnasty MI
    Quote Originally Posted by JoRoW99 View Post
    It works, but its not worth the headache convertering it to boosted stuff, and you have to run a 1bar map sensor, and 2 narrowbands if you wish to retain narrowband function.
    The only possible problem with a auto file is some stalling when you push the clutch in... Some have found a solution in a TinyTuner table about the IAC, I personally have never had issues in the 3 manual trans 3800s I have built/tuned.
  1. anyone here do a L67 fiero swap that doesn't mind me picking their braind?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 05:05 AM
  2. Low Boost cammed 3800 Fiero
    By Fieromatt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2011, 09:19 PM
  3. 2003 Trans with a 1998 PCM in an 88 Fiero Swap!
    By 3800Fiero in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2011, 09:53 PM
  4. 3800 s/c fiero swap
    By Hawkins04 in forum Off Topic Discussion
    Last Post: 07-29-2010, 11:40 AM
  5. Slow Acceleration 3800 Series III in Fiero
    By D2inDFW in forum PCM Tuning
    Last Post: 03-27-2009, 11:37 PM
