Thread: Deka IV (4) 80# injectors?
Results 1 to 20 of 47
Threaded View
  1. #29 Re: Deka IV (4) 80# injectors?
    Curious how that ties into the offset though.
    The PCM determines the PW it would require based on air/fuel model.
    Lets say 1.5 ms.
    Then would reference the voltage offset table and the map offset.
    Yet for the OSID with a min PW of ~1 the offsets are the same as the min PW of ~0.65 OSID.
    This is comparing a 1999 GTP to a 2002 GTP.
    Result would still be ~1.99 ms in both cases.
    My understanding of min PW is that it acts as a minimum PW the PCM can command before fuel trims to prevent attempting to run the injector at a rate at which it can not operate reliably and relatively predictably.
    I can see how this would be very useful for overly large or injectors accurate to much lower pulse widths.
  1. 42# injectors on an 04
    By Infinity9999 in forum PCM Tuning
    Last Post: 08-17-2009, 12:31 PM
  2. on injectors.
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-05-2009, 08:48 AM
