Thread: Overkill PCM now Stalling rough start
Results 1 to 20 of 20
  1. #1 Overkill PCM now Stalling rough start
    Donating Users kyleinkman's Avatar
    May 2011
    canada
    hey everyone i just installed a overkill tuned pcm into my 03 grand prix gtp
    my problem is if i let off the gas my car now stalls, im not getting any SES lights probally because i cant drive it far enough to let it register, my car will start up (hard) and then within about 30-40 seconds of idleing it decides to stall. also if i drive arround, if i come to a stop sign it stalls.
    When installing the pcm i Disconected the ECM fuse and the battery as suggested in overkills instructions.
    Now my question is, what is causing this to happen and where should I look to solve this issue.
    MODS:
    K&N Intake, Removed mesh air screen, flipped mounts, egr delete, NGK Cooler plugs, NGK wires, 3" pipe, Pacesetter headers, Flowmaster super 44's , 3.4 pulley, 18 inch Fast wheels rims, NanKing ns II tires, Overkill tune, comp cams. junk yard short block
  2. #2 Re: Overkill PCM now Stalling rough start
    GTP Level Member
    Nov 2008
    MA
    did you perform a "case learn" i also have an 03 with overkill v4.2 pcm and had to
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  3. #3 Re: Overkill PCM now Stalling rough start
    May 2011
    canada
    no? would it tell me i need too? also how do i do that?
    MODS:
  4. #4 Re: Overkill PCM now Stalling rough start
    Troy, Michigan
    I advise you not to drive it otherwise, until you get it situated. sounds like it could be a timing problem goodluck
    1999 Grand Prix GT - Red 8000k heads/fogs-flipped doggy bones. Looking for polished GTP wheels from a local in michigan. PM ME!
    l
  5. #5 Re: Overkill PCM now Stalling rough start
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Put the mesh back in your throttle body.
    As for a case re-learn, you would get a DTC if it was required.
  6. #6 Re: Overkill PCM now Stalling rough start
    May 2011
    canada
    ok just an update, replaced the battery and not DTC is coming up, i took video ill upload it shortly to show you guys whats hapening
    MODS:
  7. #7 Re: Overkill PCM now Stalling rough start
    May 2011
    canada
    MODS:
  8. #8 Re: Overkill PCM now Stalling rough start
    May 2011
    canada
    tried the maf, car got worse so we can rule that out
    also no i didnt floor it i cant even drive it lol i had to two foot arround my block
    MODS:
  9. #9 Re: Overkill PCM now Stalling rough start
    Quote Originally Posted by kyleinkman View Post
    Ummm dude.
    That's a rod bearing out the door.
    Sorry to be the buzzkill here.
  10. #10 Re: Overkill PCM now Stalling rough start
    GTP Level Member Austins01GP's Avatar
    Nov 2010
    Maryville, MO
    when you put the pcm in were you flooring it right away? my buddy had a similar problem cuz he was rapin it right away needa retune cuz everything got messed up
    // 1992 Nissan 300zx Twin Turbo (More RWHP than the Comp G)
    // 2005 Comp G
    CLICK ME!! for my Z Build and Comp G
  11. #11 Re: Overkill PCM now Stalling rough start
    Unplug the MAF as well...and try to start it...if it starts fine and idles fine with the MAF unplugged then you need a new one...if nothing changes...then that rules that out.
    Possibly damaged?
    No idea...it needs to idle anyways and re-learn the fuel trims.
    Something else...do you have a rear o2 or a o2 sim in there? That could be another issues as well.
  12. #12 Re: Overkill PCM now Stalling rough start
    Nov 2010
    Maryville, MO
    ouch...
    sounds like my motor when i spun a main
    sorry man
    // 2005 Comp G
  13. #13 Re: Overkill PCM now Stalling rough start
    Windsor (ON) Canada
    Maybe rename the vid, looks like your implying that the tune trashed your motor, which may not be the case. Ive had my overkill tune for about two months on my 3.4 set up and have had no problems
  14. #14 Re: Overkill PCM now Stalling rough start
    Quote Originally Posted by Colossus View Post
    Agreed.
    This was previous damage.
    Possibly done from the lack of scanning/no tune on a 3.4" setup.
    Will is a great guy and has great products...I have never heard of anyone putting in a PCM...regardless of vendor..and their motor blowing up on start-up.
  15. #15 Re: Overkill PCM now Stalling rough start
    May 2011
    canada
    yeah will is awsome but vid is implying last mod before death, changed the name of vid.
    so you guys think the engine is toast?
    MODS:
  16. #16 Re: Overkill PCM now Stalling rough start
    Feb 2009
    flintnasty MI
    broken rod bearing or not, it should still run fine.
  17. #17 Re: Overkill PCM now Stalling rough start
    Florida
    ROFL!
    Yeah, motor is toasted..Just need some butter for it.
    Poor car...
    Well time to get a scangauge, and build a badass 2.8 setup.
  18. #18 Re: Overkill PCM now Stalling rough start
    Toast is a nice way to put it...your list of mods now includes:
    3.4"
    Pacesetters
    K&N Intake
    Junkyard Short Block
    New Gaskets
    New Coolant
    New Oil/Filters
    Hopes and Dreams
    I <3 your sarcasm, asphalt man.
    No....don't doet.
  19. #19 Re: Overkill PCM now Stalling rough start
    Florida
    You're right!
    Get a GT that you wont mod, then mod it XD
    But Blue's list looks right...save the hopes and dreams..Those just got squished.
    But, with that being said, as long as the valvetrain is good, get a short block. Slap the heads, LIM, S/C, yada yada on, with new gaskets, and headers, and ta-dah!
  20. #20 Re: Overkill PCM now Stalling rough start
    GTP Level Member
    Nov 2008
    MA
    nahh all your hearing is a NIC Cam thats in there
    99 GTP - DD
  1. Rough Start/Stalling Issue
    By Bigg Dogg in forum General Tech Discussion
    Last Post: 08-18-2011, 07:08 AM
  2. rough idle hesitation and stalling
    By beast911 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-02-2011, 09:27 PM
  3. Rough start
    By 06grandprix93 in forum General Tech Discussion
    Last Post: 10-22-2010, 05:12 PM
  4. Need Help/Insight - L67 stalling/running rough
    By RebelGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2010, 02:12 AM
  5. 97 GTP - Rough idle, stalling after start?
    By Psyk in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2010, 09:08 PM
