Thread: Will i be safe or am i gonna blow it up?
Results 1 to 6 of 6
blknbstd Will i be safe or am i gonna... 10-10-2011, 08:20 PM
Hippo Machine Re: Will i be safe or am i... 10-10-2011, 08:21 PM
blknbstd Re: Will i be safe or am i... 10-10-2011, 08:28 PM
Hippo Machine Re: Will i be safe or am i... 10-10-2011, 08:32 PM
Maximum Gnarnage Re: Will i be safe or am i... 10-10-2011, 09:21 PM
CTKGP09 Re: Will i be safe or am i... 10-10-2011, 10:26 PM
  1. #1 Will i be safe or am i gonna blow it up?
    SE Level Member blknbstd's Avatar
    May 2011
    Phx Az
    i think i really caught the bug.. since i put on the 3.6 and my tune an not hitting 13.9999's at the track, i bought a 3.5 pulley and a.. oh no...... a 3.4. i know i wont be to bad with the 3.5 i have no kr at all, blips at part throttle an none throughout WOT, im gonna scan when i do my 3.5 and go from there.. but what do you really think of the 3.4, stay away without rocker or cam or other flow work such as heads? or Will i be fine if i install my water meth kit an get retuned/tweaked..
    also this is just to keep me entertained until my motor is done being built.. block is about done.. its .20 over with hypertectic pistons, i had to have the crank cut an polished an i got a VS cam an the #90 springs, i also had the lim and supercharger port and polished
    04 Comp G..... OVERKILLED/local tune water/meth 3.6, SD headers, 3in catless catback, autolite 104's lowered on SSC's and gxp brakes, DONROME STB.
    1/4mile in 14.03 at 98mph 2.4 60ft
  2. #2 Re: Will i be safe or am i gonna blow it up?
    Jun 2011
    Detroit, MI
    do u have a open cone?
    iLoveSpade
  3. #3 Re: Will i be safe or am i gonna blow it up?
    May 2011
    Phx Az
    yeah i do.. opps i didnt putting in my sig..
  4. #4 Re: Will i be safe or am i gonna blow it up?
    Jun 2011
    Detroit, MI
    It shuold be fine as long as you keep it tuned. Go any lower and I would recommend like intercooler
    iLoveSpade
  5. #5 Re: Will i be safe or am i gonna blow it up?
    Aug 2011
    colorado
    First thing first i would get and install a wideband. If you're doing a full out build with your other motor you're damn well gonna need it when you get it tuned anyway. I bet the only way you're gonna get away with the 3.4 is running pig rich and that doesn't make good power anyway. the 3.5 is probably the lowest i'd go with your mods.
    from my experience i could only run a 3.4 on my comp g with these mod's
    9" cone
    180 t-stat
    colder plugs
    headers
    1.9 rockers
    ^i got a mail order tune from zzp and bolted up the 3.4-scanned and had no kr with modest timing and commanded afr pretty dang rich
    . . . installed wideband shortly after. . . and was seeing low 10's!!! way too rich
    after tuning properly and getting my afr dialed to 11.2(still a little on the rich side) and 18* peak timing i still had a couple degrees of kr on warmer days. and that's with rocker's. i'd try the 3.5 see how it goes, then you can try the 3.4 if you want but just cuz you can run the pulley doesn't mean your making the power. . .
    anyway that's my .02
  6. #6 Re: Will i be safe or am i gonna blow it up?
    Willoughby, Ohio
    every car is gonna be different but i would do as stated above and keep a CLOSE eye on it
  1. Blow my engine?
    By astros2900 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-29-2011, 04:56 AM
  2. Taillight blow out
    By jluca in forum General Tech Discussion
    Last Post: 12-04-2010, 08:22 PM
  3. blow out
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 11-26-2009, 06:14 PM
  4. When will my transmission blow
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2009, 08:31 AM
  5. Whats Wrong Did I Blow It Up ?
    By p5773566 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2009, 06:10 PM
