Thread: Diving into tuning [2005 Grand Prix Base]
Results 1 to 5 of 5
  1. #1 Re: Diving into tuning [2005 Grand Prix Base]
    GTX Level Member Juanmiguel's Avatar
    Mexico
    higher O2s are richer, lower are leaner. I still use a narrow band, but started using commanded AFR for the time being instead of the O2s.
    Given you're basically stock your MAF table should be fine, just check if your LTFTs are in +-3.
    Things you want to look into:
    -More timing (cruise and wot).
    -lower AFR in WOT or PE mode.
    -torque management (disable injector or fuel disabling. Leave spark retard for torque management.)
    -transmission settings for perf shift (shift points and oil pressure)
    -lower temp fan settings along with a colder Tstat
    If I were you, I would take a base canned tune like DHP, Import the stock MAF table and start from there.
  2. #2 Re: Diving into tuning [2005 Grand Prix Base]
    Springfield VA
    The Perf shift settings have already been swapped copied to the regular shift settings, and ive modified the fans to run after the car is off [god send at autocross] but i dont have a colder t stat so ive left them at the stock turn off and on points.
    is there a way to get the car to hold first longer, or better yet not shift itself out? id rather bang off the rev limiter during autox then have the car shift into second, wallow around in the bottom of second, then finally decide it wants to do something and shift back down.
    Quote Originally Posted by UR LOSN View Post
    all depends on how fast/broke you want to go.
  1. Supercharger for '07 grand prix base model 3.8 L26
    By tino153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 08:14 PM
  2. Cold Air Intake on base grand prix???
    By rashan in forum General Tech Discussion
    Last Post: 09-29-2010, 01:25 PM
  3. 2008 Grand Prix Base Wheels
    By ajaxjblue in forum Tires & Wheels
    Last Post: 10-05-2009, 12:33 PM
  4. Remove back speaker of a 2005 Grand prix base.
    By Lentrave in forum Audio, Security & Visual Electronics
    Last Post: 09-08-2009, 07:32 PM
  5. TC on a 2006 base grand prix
    By nrfitchett4 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2009, 06:06 AM
