Thread: power enrichment timer
Results 1 to 7 of 7
  1. #1 Re: power enrichment timer
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by SnowFlake View Post
    If you're going to delete the table up to 14-16 seconds make sure you adjust your PE AFR down to compensate... although if you do it this way, when you do hit the AFR/Time cells that start adding fuel, the AFR is going to plunge.
    Personally I don't touch this table as AFRs can be stabilized using other methods.
    If you are trying to get your wideband afr's to match your commanded afr's the pe vs time table can mess this process up. By deleting this you are making the process easier. The point IS to let it richen up after 14 sec...?
    I don't know why you wouldn't want to keep things simple...
  2. #2 Re: power enrichment timer
    SE Level Member xBlacKxGTPx's Avatar
    springdale ar
    is it normal to be in the positive on this table? i tryed to do a little WOT with narrow band and now that i have wideband ive taken a crap load of fuel out. normal or not?
    i took off 16+ and there was a slight change in the afr but it seems to be getting richer with time it does not stay the same for every 5 seconds and when i hit 2nd gear it get really rich it jumps from 11.3 to 10.6. should i find the correct value and change the whole table?
  1. Power enrichment / time necessary?
    By Juanmiguel in forum PCM Tuning
    Last Post: 05-14-2011, 03:30 PM
  2. just another 1st timer saying hi, from nc.
    By ak47 in forum Introductions/Noob Questions
    Last Post: 07-31-2010, 02:34 PM
  3. Yep, I'm a 1st timer!
    By telkel2399 in forum Introductions/Noob Questions
    Last Post: 12-05-2009, 07:06 PM
  4. Old Timer Newbie
    By GUTZGTP in forum Introductions/Noob Questions
    Last Post: 10-13-2009, 04:52 PM
  5. First Timer
    By kygtp in forum Introductions/Noob Questions
    Last Post: 10-22-2008, 10:27 AM
