Quote Originally Posted by FoSHO99 View Post
PE vs. Time just delete everything up to 14-16 seconds. That way it doesn't mess with your AFR during the 1/4 mile and if your playing around it's there to help some. If you're WOT for more time than that, you're not very smart, so let the pcm add some more fuel to save your ass.
If you're going to delete the table up to 14-16 seconds make sure you adjust your PE AFR down to compensate... although if you do it this way, when you do hit the AFR/Time cells that start adding fuel, the AFR is going to plunge.
Personally I don't touch this table as AFRs can be stabilized using other methods.
