I tried posting this question on the chat but my pc decided to sh!t on me and my phone net isn't fast enough so here I am and it has to do with pcm and kinda tuning. I got my auto tap in a few days ago and I've done three logs, three seperate days, all the same weather and same driving conditions at the same time of day. The car is a 97 gtp with mods in my 1600 E. Hwy. 70 Spc. 63
Taman86.
I've been having driveability issues for over a month now. I got a p0102 dtc fixed but it still drives like garbage. When in open loop it drives, accelerates, shifts fine with no problems but as soon as it switches to closed loop after warm up I can literally feel it switch. Ide be cruising at 38 at around 1600 rpms then when it switches the rpms drops to about 1300 and it sounds like it has no res on. The logged data that I did notice is the commanded afr is 14.7, the O2's are jumping from 8xx to 7x back and forth like that and I'm getting up to 2.x of kr when shifting. When in closed loop and I take my foot of the throttle the rpms hang for a second before dropping to about a 1000, then when I put my foot back on the throttle just cruising to maintain speed at say 40 the rpms will go up to about 1800 then drop back down to about 1400 and the exhaust sounds loud again. When I try and give more then 40 percent throttle it starts to knock and sputter but won't down shift. Does any one have any insight as to where I should start looking?
