Thread: LTFTs changed, why?
Results 1 to 15 of 15
  1. #1 LTFTs changed, why?
    GTX Level Member Juanmiguel's Avatar
    Mexico
    So last time I scanned my car it was like 2 or 3 weeks ago and my trims were right on spot.
    Today I scanned it again and now the LTFTs are in the -22s STFT are still on target.
    I haven't done any changes since then. Why could this be?
  2. #2 Re: LTFTs changed, why?
    Charles City, IA
    Did it get hotter?
    SMGPFC Two Nipple General
  3. #3 Re: LTFTs changed, why?
    Mexico
    yes
  4. #4 Re: LTFTs changed, why?
    Charles City, IA
    that is why, hotter= less dense air = richer.
  5. #5 Re: LTFTs changed, why?
    ^yup
  6. #6 Re: LTFTs changed, why?
    Mexico
    got it. I didnt think it would make that much of a difference. I will just have to create a diferent tune for every season. thanks.
  7. #7 Re: LTFTs changed, why?
    Charles City, IA
    Yup.
  8. #8 Re: LTFTs changed, why?
    Jan 1970
    Maquoketa, Iowa
    well your in mexico, so what was the actual difference? Up here it's a little more drastic. You shouldn't be that far off unless you may have rushed the maf tuning or not let the fuel trims relearn while tuning?
  9. #9 Re: LTFTs changed, why?
    Mexico
    i think it was between 20 and 25 Celsius during the day when I tuned the MAF table, always let the trims relearn. The trims were on target during the rest of the tuning process (a few weeks). Right now it's between 24 and 34 C during the day.
    I actually scanned today during the hottest hour of the day in traffic and with the A/C turned on to get the ETCs near 100 C. I wanted to make sure that I wasn't getting any KR at that temp.
  10. #10 Re: LTFTs changed, why?
    Jan 1970
    Maquoketa, Iowa
    And it's still pegged rich after parking the car a few times? You have evap deleted?
  11. #11 Re: LTFTs changed, why?
    Mexico
    I'm not sure what you mean with that. Do you mean letting it sit for a while? If that's the case, then I don't know I only noticed that today on the way back from the office. I haven't scanned it again since then.
    I haven't deleted the evap either.
    Here's the average LTFTs that I got today:
  12. #12 Re: LTFTs changed, why?
    Florida
    have you zero'd out your air temp spark table? if you have this might hurt a bit too. i use this table to pull or add timing to keep my trims and AF where i want them. i dotn know HP tuners but i think eddie has the option in his minituner to adjust something along the lines of Air Temp AFR
  13. #13 Re: LTFTs changed, why?
    Mexico
    No, I actually deducted timing at higher IATs and also deducted timing to the ECT/spark table past 90*C since I was getting some KR at this point. So the objective of doing this scan was to check if it actually worked, and it did.
    I also scanned it again the a couple of days later and the LTFTs were back in place. I guess they change when driven at higher ECTs and with the A/C turned on.
    I don't use HP tuners by the way, it's DHP too.
  14. #14 Re: LTFTs changed, why?
    Florida
    lowering timing will cause trims to go neg as you are not burning as much fuel... Great to see they are where you need them.
  15. #15 Re: LTFTs changed, why?
    Mexico
    Oh I see now, that explains it all. Then I can leave it as it is for now. I may not need to pull timing at higher ECTs once I get the IC installed.
    Thanks
  1. Things sure have changed
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 10-12-2010, 02:40 AM
  2. for those of you that changed. upgraded rad
    By kuntzie in forum General Tech Discussion
    Last Post: 07-04-2010, 09:24 PM
  3. LTFTs at -22.06
    By 2001GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-05-2010, 12:22 PM
  4. So alot has changed.....
    By GTPJOE90 in forum Visual/Body Modifications
    Last Post: 03-23-2010, 05:27 PM
  5. stuck in open loop and LTFTs pegged at 0.0%
    By fst in forum PCM Tuning
    Last Post: 05-02-2008, 08:57 AM
