Thread: dhp help
Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
  1. #21 Re: dhp help
    Bastard Reptile's Avatar
    Kansas City, MO
    Is this a stock PCM or was it modified by someone?
  2. #22 Re: dhp help
    TN
    Stock as far as I know.
    Most of its life[ the first 100 thousand] was spent with its two other owners and 25,000 with me
    also one other thing,when I read the pcm it had to manualy read it
    88 fiero formula l67
    04 ninja
  3. #23 Re: dhp help
    Quote Originally Posted by Soviet View Post
    Hmm. Could just be what it said, and unsupported OSID. If you post the bin it read, one of us can confirm it. Simplest solution if it isnt supported (likely due to it being an older and less common osid) would be to use a newer osid for your car. You can enter your vin at TIS and find all the osids supported. I likely can provide you with a sotkc copy of one of the osids it finds.
  4. #24 Re: dhp help
    TN
    Thank you I have to look in the morning because it locks the bin file when i try to open it with a error message 73 or i could go outside now but i rather not get yelled at
    04 ninja
  5. #25 Re: dhp help
    TN
    vn-1g2wp52k8yf135628
    by what i understand it has been reprogram so whats the next step
    04 ninja
  6. #26 Re: dhp help
    Hmm. If you could post the bin you read out, it would be appreciated. Likely a bin not mapped that could be added..
    Anyway, your bin is likely cal/os id 9384045, which is not supported by the PowrTuner.
    The newer cal/os id for your vin is 9389750. That one is supported. Check your PM for help with that.
dhp
