Thread: dhp help
Results 1 to 20 of 26
  1. #1 dhp help
    TN
    I just got a dhp today, I have got the framework 1.1 program and the mdac program but I still cant get connection to the tuner wire/box from my laptop which is a window 7 32 bit to the car.
    The computer chimes after hooking up the usb connector converter which is hook to the tuner but dosen't state it is connected.
    my next step is geting a different usb converter maybe a keyspan
    any more advice
    88 fiero formula l67
    04 ninja
  2. #2 Re: dhp help
    Charles City, IA
    miker....something just went threw the same thing. Not sure what he had to do, but he did get it working with 7.
    SMGPFC Two Nipple General
  3. #3 Re: dhp help
    Jan 1970
    Maquoketa, Iowa
    i think he dual booted and used xp, there is a few different tricks to try for windows 7, but i don't have that info. right now.
  4. #4 Re: dhp help
    TN
    couldnt find miker but i did find a mikey with around 240 in post is that him
    sorry but no the only laptop i have is my win 7
    04 ninja
  5. #5 Re: dhp help
    Jan 1970
    Maquoketa, Iowa
    Dhp was never really meant to run on Windows 7, do you have something that has xp you can use?
  6. #6 Re: dhp help
    Keyspan + Windows 7 drivers for it + DHP program always run as administrator (or UAC turned off, your choice) = working fine every time.
    Since you dont have a keyspan, make sure you have/do the others. If that doesnt work, the usb/serial adapter either is not working to hot in Windows 7 or just is not going to cut it either way.
  7. #7 Re: dhp help
    TN
    I got the coverter to lite up by installing a driver made for vista but the rain is keeping me from testing it on my car so I will update the thread if it stops raining
    04 ninja
  8. #8 Re: dhp help
    GTX Level Member Juanmiguel's Avatar
    Mexico
    Where did you get the vista driver? I'm pretty sure I'm gonna have the same problem once I get mine. I'm also running W7 on my laptop.
  9. #9 Re: dhp help
    TN
    I have a belkin connector, that came with the tuner.
    I went to the belkin site then to support and after a few pages,I found a download page that u had choose ur item's serial #.
    Then it gave me a list of free programs.
    just as updateing the computer accepted the dhp i think but unsure on where to find the codes to start a read
    where do i find them
    Block 0A
    : This field displays the OS
    Identifier for your PCM.
    Base Model and End Model
    : These
    fields are also OS identifier fields.
    Seed
    : This field reflects part of the
    PCM security information.
    Interface Ver #
    : This reflects the
    version of the DHP Interface. The
    current version is 2.0 for the interface.
    04 ninja
  10. #10 Re: dhp help
    Bastard Reptile's Avatar
    Kansas City, MO
    I've got a Belkin connector on mine too, and once you download the drivers, it should work.
    The keyspan craze.....lol Good old Mike N on the other forum probably made a done of money off that scam.
  11. #11 Re: dhp help
    Quote Originally Posted by Reptile View Post
    Not a craze, owned several adapters such as the Belkin ones before I even owned a PowrTuner. Some fo the pricier Belkins are OK. But by testing with other more demanding serial devices I can tell you that Keyspan is about as good as it gets short of a real serial port. Especially further back with older versions of Windows. Drivers by certain other vendors were real POS and incompatible with certain other components not seen in every computer.
    Still, given drives and a working adapter, PowrTuner should run just as well or as bad in Windows 7 as it would in XP.
  12. #12 Re: dhp help
    Donating Users
    Parma, Ohio
    realistically you shouldn't need to install the drivers, win7 automatically gets those. for all programs meant for another system right click and run as admin, or get a WinXP emulator downloaded on the win7. then run the program from the winxp emulator..
    2003 Subaru Impreza WRX
    2008 Saturn Aura
    2000 Bright Red GTP coupe. RIP 11/6/11
  13. #13 Re: dhp help
    Kansas City, MO
    Quote Originally Posted by Ballin00gtp View Post
    I admit, it's pretty good, but I had to fiddle with the setting just to get my HPT to run on the 64 bit system. Ended up having to download a program so that I could actually edit they setup.exe file to NOT look for a specific version of the .net 4 framework.......or something along those lines.
    It was one of those things that started in the evening, and ended up waaay in the night before a friend helped me find what I was needing.
  14. #14 Re: dhp help
    Donating Users
    Parma, Ohio
    yeah i had to do that for my cousins before he fried the system... it was a pain. but atleast now i know for when/if i decide to get one.. i do need a new tune tho..
    2008 Saturn Aura
  15. #15 Re: dhp help
    TN
    Just as a note i got the conector to lite up so now i need to know where find the codes for the next step [they r listed above]
    04 ninja
  16. #16 Re: dhp help
    Kansas City, MO
    I'm not sure what you're meaning by codes?
    You'll have to have the dhp connected to the com port on the car and then to the computer to register the interface. Then you'll need to click on the PCM Flash/Read PCM tab and download your .bin file for your tune.
  17. #17 Re: dhp help
    TN
    Alright I will try again in the morning.
    04 ninja
  18. #18 Re: dhp help
    Kansas City, MO
    I'm not saying that the performance aspect of the keyspan isn't superior....sorry if it looked like that. It was just that when Charles started selling the Powrtuner, he and Mike had struck a deal on the CGP store to exclusively recommend a keyspan adapter for like $30 in order to not void your warranty. Went so far as to say that, I know, and further to say you won't get connectivity with any other, you could fry something. Which is completely false. It was completely ridiculous. I got my adapter at best buy and I've never had an issue with it. The only problem is/was Vista, and that was mainly people had problems with the actual DHP program itself with most of the versions wouldn't work with Vista. Now with me, I use the DHP exclusively on my desktop now to program mail tunes, my laptop has Win 7 64 bit, and even with HPT it was a chore to get it installed since the base program hasn't been updated since I think 2009.
    I guess what I'm getting at, was it was yet another way for people to make extra money providing false information 5-6 years ago, when someone could have went and got their own serial adapter and not have to wait 1-2 weeks to use their product.
  19. #19 Re: dhp help
    Jersey
    Vista is terrible with dhp. I switched to xp. My keyspan fried, i bought one from radio shack, works awesome.
    16' wrx sti- stock
  20. #20 Re: dhp help
    TN
    Well while fight on which connector is beter, I got it read but it gave me a error 73 after the reading was complete
    by the way error 73 =
    Unsupported File Type, contact DHP
    My problem the site gmv6pcm is really unvisited now so what can i do
    04 ninja
dhp
