Thread: Disabling Cat Diagnostics
Results 1 to 14 of 14
Threaded View
  1. #4 Re: Disabling Cat Diagnostics
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Bedwards View Post
    I wanted to replace that O2 sensor with a wideband. Won't be possible?
    I did that with mine and I have not had any issues. If you have hp tuners just uncheck ses enable on the po420 dtc. See if you start getting 16.4 lfts when you are at a cruise or idling. if you do chances are you will need to rerun the rear 02
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  1. tcc lockup disabling???
    By 513yj in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 10:08 AM
  2. Professional Installs, diagnostics and maintenance PA
    By silvermistwbody in forum Northeast
    Last Post: 07-27-2009, 09:30 PM
  3. Diagnostics on a Head Unit
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 10:39 PM
  4. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
