Thread: Disabling Cat Diagnostics
Results 1 to 14 of 14
  1. #1 Re: Disabling Cat Diagnostics
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    you have a wideband in your rear o2 sensor bung after the cat?
    Yes, however I don't have a cat, I have headers.
    I am assuming he did not install a cat with his speed daddys and is just using the extra bung in the rear.
    Correct.
    Quote Originally Posted by Lawngoose View Post
    Bedwards I was a victim of the 16.4 issue. If you can load a bin file into hptuners...let me know I got a fix. Mines a 2002 btw.
    Quote Originally Posted by gtpracer0186 View Post
    I have the same problem, what did you do to fix it?
    Thanks
    I didn't adjust anything. I don't even have my HP Tuners yet (should arrive anyday though ). I have an Intense custom mail-order tune right now with the option "Disable rear O2 sensor DTC's" selected. I took my rear O2 out, and replaced it with the wideband. Car runs perfect and fuel trims are exactly the same.
  2. #2 Re: Disabling Cat Diagnostics
    Jan 1970
    Maquoketa, Iowa
    You can disable it in Tiny Tuner. I'm not on here or don't have much time to post here anymore, but it is possible in Tiny Tuner. Look in diagnostics> cat diagnostics and set the cat diagnostics to 0.
  1. tcc lockup disabling???
    By 513yj in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-18-2009, 10:08 AM
  2. Professional Installs, diagnostics and maintenance PA
    By silvermistwbody in forum Northeast
    Last Post: 07-27-2009, 09:30 PM
  3. Diagnostics on a Head Unit
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 10:39 PM
  4. disabling DRL's?
    By TJs97 in forum General Tech Discussion
    Last Post: 09-10-2008, 11:18 PM
