Thread: Some of my Scans
Results 1 to 7 of 7
  1. #1 Re: Some of my Scans
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    Quote Originally Posted by Lawngoose View Post
    . I still get knock... so I am thinking that I need to richen the lower part of the MAF table.
    Your LFT's are Negative Around -4 to -5 during your cruise. What makes you think you need to add fuel?
    . Now the debate... Many ppl will say to tune your LTFT's to - values. The reason being that you are running rich and the pcm is removing fuel. The other end of the argument is to tune your trims + .. so the pcm is adding fuel. However, if you adding fuel... your already running to lean right?
    Pulling fuel at WOT (negative valve) is something you DO not want.
    . Im going to do another scan tomorrow morning (when temps are colder) to see what happens on another MAF adjustment. However, I do have a question.. if my fuel trims are + and I wanted to manually adjust the table to make them - ...wouldnt I reduce the table values??
    I see Negative LFT's (Cruise.) Going off your last scan. Do not take into consideration the Plus 8 you see on deceleration or the Plus 3 to 6 you see at idle
    I have virtually no knowledge about timing changes...other than using eddie's tool to change timing on WOT runs when you get KR.... so any info is appreciated.
    Im not sure on DHP but on HPT its in the last table line on the spark table
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
  2. #2 Re: Some of my Scans
    Outer Space
    According to the DHP Tuning Bible aka Jerry's Notebook....
    Please note, we are always going for trims lightly in the negatives or 0, but never into the positives. This means that the PCM is adding fuel because our settings are making it go too lean. Better to be slightly rich than lean.
    Source: Tuning Your MAF Table - OpenTuner Notebook
    I use a table modifier prog... that basically removes all decel fuel cells... and averages all the fuel trims (at least that is how I have mine set). Looking at the output on this file (I emailed it to you with SUBJ line: More BS) ... my Lower MAF hz (im sorry i put higher on my previous post) are + when my higher hz range is -. Using the logic from the tuner notebook... I want trims slightly -. I can post it in the thread if anyone wants me too.
    I don't care about idle and decel fuel cells.
    So, this isn't meant to point fingers or say someone is wrong.. or compare e-cocks. This is how I learned to tune... whether its right or wrong, I definitely want to know. I enjoy talking about tuning, and finding out what others are doing. I am no pro by any means.... just seeking knowledge
    /hug
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Some of my Scans
    Hagerstown,Md
    I disagree with that statement. Id rather have a PCM adding fuel blindly off a narrowband readout then pulling fuel blindly. Esp under WOT conditions
    You would know better of what your trims are doing. I was looking from just two scans. The goal is +3 to -3. Cruise IMO doesn't make a difference of plus or minus if your in that range LFT's should lock at 0 WOT. WOT is another story. A average of trims isnt a good idea IMO as you can be lean in one section of the HZ and rich in the other. But as I said I have no experience with Tiny tuner/table mod program. Alot of people use them. I just use histograms
    Thats what I was saying. Decel cells do not effect PE locking
    Good because mines HUGE!.
  1. my scan
    By 99prixgt in forum PCM Tuning
    Last Post: 09-05-2010, 03:11 PM
  2. take a look at this scan!
    By RICE KILLER in forum PCM Tuning
    Last Post: 07-15-2010, 08:23 PM
  3. kr scan
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2010, 08:17 AM
  4. My first scan... wth is going on?
    By PonchoDvr4Lfe in forum PCM Tuning
    Last Post: 10-22-2009, 09:55 AM
  5. help with scan
    By ldyzluvdis06 in forum Midwest
    Last Post: 06-01-2008, 09:05 PM
